February 21st, 2015, 02:55 PM | #1 |
Join Date: Aug 2011 Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom Posts: 898
Question about Fork Oil
Not sure where to post this since it's about my FZ6, not a Ninja. There doesn't seem to be a general maintenance forum that isn't specific to a certain model of Ninja. So mods, feel free to move this.
So I'm in the process of doing the R6 fork mod to my bike. I ordered two separate fork legs off of eBay. One was new old stock and the other was a used unit. When I flip the used fork leg upside down and then right side up I can hear the oil going from one end to the other. When I do the same thing with the NOS fork leg I can hear the oil but it's very faint If I hold the NOS fork upside down when I flip it back it seems to take at the most 1 second for the oil to stop moving. With the used fork it takes closer to 5 seconds. Help! |
February 21st, 2015, 03:01 PM | #2 |
Sounds to me like you should flush the used unit out, then refill it to the factory suggested level. They lose some oil over time and get sediment and general crud in it that plugs stuff up.
February 21st, 2015, 03:03 PM | #3 |
Join Date: Nov 2012 Motorcycle(s): '07 ex250-F/J Posts: A lot.
I don't know too much, but you think there are bubbles in there? You gonna be changing the oil?
February 21st, 2015, 07:07 PM | #4 |
Each may have different volume and grade of oil inside.
February 21st, 2015, 07:28 PM | #5 |
the used fork needs to be R.D.I. anyway.
Change the fork oil to what your riding needs are, a good weight for me was 15w in the Ninjette, in my EX I run 30w Fill to the OEM specs!!! each one is different.
February 21st, 2015, 07:41 PM | #6 |
Sell the used unit and buy another new old stock. U want the same forks imho
February 21st, 2015, 07:53 PM | #7 | |
Better than new Also gives you the perfect excuse to modify the fork springs, and set that sag height finally
February 22nd, 2015, 10:39 AM | #8 |
What does RDI stand for?
It sounds like I should take both fork legs to my local shop and have the oil changed so that they match, eh? |
February 22nd, 2015, 10:51 AM | #9 | |
disassemble inspect
February 22nd, 2015, 11:52 AM | #10 |
ah... thanks! Definitely taking these forks to the shop then, that's above and beyond my skill level.
February 22nd, 2015, 01:11 PM | #11 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
Not really; it's pretty simple. A service manual will take you through it step-by-step with pictures. They pay for themselves pretty much the first time you use them.
Profanity is the weapon of the witless. |
February 22nd, 2015, 08:01 PM | #12 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
I would remove disassemble and inspect! Just go slowly and line up your parts in the order in which they came out in the relative positions in which they go inside the fork. If you screw up you can look at a parts fiche or the service manual. Drain the oil and re-fill.
Shops charge a LOT for doing work on the forks. While you have them off the bike, you should go through them in case you ever need to do it in the future (replacing fork seals costs $350)
Instagram: @katie.baden |
February 22nd, 2015, 08:06 PM | #13 |
Also do one at a time, don't do both together, at least this way you have a complete one to reference.
February 22nd, 2015, 08:07 PM | #14 |
ran when parked
Also, you don't need to disassemble the forks to change the oil. Just take the cap off, take the washer and spring and spacer out, tip it upside down and drain the oil, then refill using the service manual capacity or the level with the spring OUT, and put the cap back on.
February 22nd, 2015, 08:17 PM | #15 |
Eh. I'll just pay. My shop charges $175 for seal replacement labor. Not too bad. I work 55 hours a week and am studying for some exams about 20 hours a week. So I'd rather just pay someone else to do it. It'll save my sanity.
Plus I want someone with experience to do the inspection of the used fork. I wouldn't be able to spot an issue. |
February 22nd, 2015, 08:18 PM | #16 |
ran when parked
Sweet! Hopefully they can clear up the mystery for you. Let us know what they say, I am curious too
February 23rd, 2015, 08:40 AM | #17 |
Will do, I'll probably take them to the shop this upcoming Saturday.
DIY- Replace fork seals, dust seals and fork oil | shortstuff | 2008 - 2012 Ninja 250R Tech Talk | 212 | November 6th, 2023 10:53 AM |
fork oil question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 16 | August 19th, 2014 06:40 PM |
Fork oil question | sharky nrk | Ninjettes At Speed | 7 | September 13th, 2013 04:00 AM |
Fork oil | jconolty | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 11th, 2013 11:33 AM |
Fork Oil | nexus | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 20th, 2011 08:42 PM |
