Old April 4th, 2021, 04:16 PM   #121
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
righteous
RIDE IT UNTIL THE WHEELS FALL OFF, THEN BUY NEW WHEELS
JayVapes is offline   Reply With Quote
Old April 7th, 2021, 05:27 PM   #122
ducatiman
ducatiman's Avatar
This 250 refurb completed today, can't do any better than these, note EX500 rail filter plugged in. Tighter, it has more of a tendency to stay put. Found the 250 filter on these displaced and wedged up inside the fuel line an inch or so.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; April 9th, 2021 at 07:55 AM.
Old April 8th, 2021, 02:01 AM   #123
JayVapes
JayVapes's Avatar
I recommend your work always!
Old April 8th, 2021, 09:02 PM   #124
JayVapes
JayVapes's Avatar
xp that was my filter down inside that line. I have no idea how the motorcycle even ran!
Old April 9th, 2021, 05:13 AM   #125
ducatiman
ducatiman's Avatar
Haha, I had no idea that was you responding in the thread here, JT!
If it ran (at all) before, it should run awesome now. We shall see.
Custom Carb Service
Old April 9th, 2021, 05:16 AM   #126
ducatiman
ducatiman's Avatar
note kink in the vent line i referred to, textbook otherwise.
Custom Carb Service
Old April 13th, 2021, 12:16 PM   #127
ducatiman
ducatiman's Avatar
EX500 carbset refurbed today, these for sale, my property
Custom Carb Service
Old April 16th, 2021, 10:28 AM   #128
ducatiman
ducatiman's Avatar
^ SOLD ^
with yet another 500 set in the works, again my property, will be for sale
Custom Carb Service
Last futzed with by ducatiman; April 18th, 2021 at 05:57 AM.
Old April 22nd, 2021, 05:34 PM   #129
ducatiman
ducatiman's Avatar
today, knocked off a set of ZR750 Kaw carbs, Keihins reminiscent of 2# linked EX250 sets.
Custom Carb Service
Old April 23rd, 2021, 12:04 PM   #130
ducatiman
ducatiman's Avatar
back to EX500's today
Custom Carb Service
Old April 25th, 2021, 12:16 PM   #131
ducatiman
ducatiman's Avatar
Echo blower and Craftsman weed whacker both got running today, both needing carb work....belonging to my (lucky) next door neighbor. Ditto on his pressure washer just a couple weeks ago.
Custom Carb Service
Old April 26th, 2021, 05:54 PM   #132
ducatiman
ducatiman's Avatar
back to a 250 carbset today
Custom Carb Service
Old May 6th, 2021, 03:10 PM   #133
ducatiman
ducatiman's Avatar
received at 10am, refurbed and shipped back out by 4:30 today. Not too shabby if i don't say so myself. Now bolt on runners, problems included missing pilot screw orings and a frozen in place decel valve diaphragm.
Custom Carb Service
Last futzed with by ducatiman; May 6th, 2021 at 04:49 PM.
Old May 6th, 2021, 07:51 PM   #134
JayVapes
JayVapes's Avatar
so modest
Old May 8th, 2021, 11:38 AM   #135
ducatiman
ducatiman's Avatar
finished another set of 500's today which underwent quite a transition. Both pilot jets and emulsion tubes were clogged, badly varnished.
Custom Carb Service
Old May 9th, 2021, 06:51 AM   #136
ducatiman
ducatiman's Avatar
been advised of Mikuni/Ducati carbs incoming
Custom Carb Service
Old May 15th, 2021, 06:22 PM   #137
ducatiman
ducatiman's Avatar
especially nasty Ducati/Mikuni's still in process. A couple before/after shots. To update when done tomorrow.
Custom Carb Service
Old May 16th, 2021, 03:56 PM   #138
ducatiman
ducatiman's Avatar
all done, 1 more before/after shot
Custom Carb Service
Old May 19th, 2021, 07:24 PM   #139
ducatiman
ducatiman's Avatar
a nasty set of EX500 carbs here for normal refurb. Final pics tomorrow. Lets see if we can wake these up a bit.
Custom Carb Service
Old May 20th, 2021, 11:24 AM   #140
ducatiman
ducatiman's Avatar
yup, now awoken to bolt on runners.
Custom Carb Service
Old June 7th, 2021, 07:35 AM   #141
ducatiman
ducatiman's Avatar
Today 3 items incoming from landscaper to me.
The first, a non-starting Craftsman pressure washer already done. Required a carb pull/clean (NO parts). New fangled carb featuring plastic body/internals......now starts 1st pull , goes into reliable steady idle.
Custom Carb Service
Last futzed with by ducatiman; June 7th, 2021 at 02:05 PM.
Old June 11th, 2021, 06:15 PM   #142
ducatiman
ducatiman's Avatar
Vulcan 500 carbset refurbed today, using a new general cleaner. Worked out well, restored brass tuning components like new, carb bodies greatly improved over what was received.
Custom Carb Service
Old June 19th, 2021, 01:49 PM   #143
ducatiman
ducatiman's Avatar
These 2 fitties came out no less than spectacular today. Using a newfound cleaner...as clean inside as outside. Wet tested, fuel levels tweaked, ALL circuits confirmed clear...these'll bolt on and GO (the general idea)
Custom Carb Service
Old June 20th, 2021, 05:09 PM   #144
ducatiman
ducatiman's Avatar
Knocked these 500's off today, will be fine runners. Note restored to like-new factory supplied brass tuning components.
Custom Carb Service
Last futzed with by ducatiman; June 20th, 2021 at 06:17 PM.
Old June 25th, 2021, 09:36 AM   #145
ducatiman
ducatiman's Avatar
Today a set of 4 banger Keihin FCR39 for Honda CB900RR on the bench. A ton of parts, better pics to follow. So far, findings include 3 of 4 pilot jets totally clogged. Further advised bike has sat for 7 years.
Custom Carb Service
Last futzed with by ducatiman; June 25th, 2021 at 07:29 PM.
Old July 6th, 2021, 12:45 PM   #146
ducatiman
ducatiman's Avatar
the FCR's await seals. In the meantime........
Custom Carb Service
Old July 7th, 2021, 09:02 AM   #147
ducatiman
ducatiman's Avatar
Oh oh, torn diaphragm on 250 set i'm currently doing.
Custom Carb Service
Old July 7th, 2021, 04:08 PM   #148
ducatiman
ducatiman's Avatar
new diaphragms installed, carbs done, they worked out quite nice. EX500 mesh rail filter installed.
Custom Carb Service
Last futzed with by ducatiman; July 7th, 2021 at 05:10 PM.
Old July 8th, 2021, 12:29 PM   #149
ducatiman
ducatiman's Avatar
and a set of fi' hunnerts done today.
Custom Carb Service
Old July 10th, 2021, 03:55 PM   #150
ducatiman
ducatiman's Avatar
seals (not supplied in kits) finally arrived today allowing me to complete these FCR39's from a Honda CBR900.
Custom Carb Service
Old July 12th, 2021, 11:21 AM   #151
ducatiman
ducatiman's Avatar
today, in quite the transition, i'm on a single carb from an older '82 Honda CM250. Worked out well.
Custom Carb Service
Old July 13th, 2021, 05:32 AM   #152
This thread is not good for my diet......
Too many carbs.....
Old July 13th, 2021, 12:57 PM   #153
ducatiman
ducatiman's Avatar
Working on poorly set up 250 carbs today. Inactive, dead slides...replacement diaphragm rubbers incorrectly installed, and dead floats.... amongst other problems.
Completed pics will follow.
Custom Carb Service
Last futzed with by ducatiman; July 14th, 2021 at 07:08 AM.
Old July 24th, 2021, 03:52 PM   #154
ducatiman
ducatiman's Avatar
500's done today turned out textbook perfect.
Custom Carb Service
Old July 27th, 2021, 01:01 PM   #155
ducatiman
ducatiman's Avatar
Near done today , a Keihin set from a Honda CBR250RR MC22 (Australian model) aka "Babyblade" here for a "functional clean".
Refurbed original jetting installed, the kit the owner supplied used different sizes....opted to stick with OEM 105/102 mains (note inner and outer main jets are sized differently)
Not perfect, but greatly improved in a visual sense, I do anticipate will be fine runners.
Custom Carb Service
Old July 27th, 2021, 05:53 PM   #156
ducatiman
ducatiman's Avatar
finished this evening
Custom Carb Service
Old July 28th, 2021, 07:41 AM   #157
Old August 8th, 2021, 01:52 PM   #158
ducatiman
ducatiman's Avatar
Rained near all day here.....perfect time to tackle some equipment maintenance prior to knocking this 250 set off, which came out near perfect.
Custom Carb Service
Old August 10th, 2021, 08:22 AM   #159
ducatiman
ducatiman's Avatar
rained yet again.....so I knocked off these EX500's. What the heck, can't ride anyways.
Custom Carb Service
Old August 17th, 2021, 01:23 PM   #160
ducatiman
ducatiman's Avatar
Nope, not the same, but another set of 500's came out nice today. Bolt-on runners, yup. Shiny brass, yup. All original tuning components restored/reused.
Custom Carb Service
[roadracingworld.com] - Yamaha VR46 Master Camp Video: Day Four Was A Special Day For Ninjette Newsbot Motorcycling News 0 May 26th, 2019 10:52 AM
[roadracingworld.com] - â??Racers Edge Performance Hosting Track Day/ Practice Day Ap Ninjette Newsbot Motorcycling News 0 March 25th, 2015 02:20 PM
[kropotkin thinks...] - IMS Press Release: A Day-By-Day Guide To What's On At The Red Ninjette Newsbot Motorcycling News 0 August 5th, 2014 09:30 AM
[motorcycledaily.com] - Max Biaggi Finishes First Day of Two-Day Ducati MotoGP Test ( Ninjette Newsbot Motorcycling News 0 June 6th, 2013 05:10 PM
[kropotkin thinks...] - Shots In The Dark, Day 4: Scott Jones, Race Day Ninjette Newsbot Motorcycling News 0 April 9th, 2013 03:50 AM
