January 20th, 2011, 12:53 AM | #1 |
Front brake reservoir in the way
I'm not sure if I have a long torso or what but I am finding that the angle of the front brake lever would be more comfortable if it was lower. Problem is that the brake lever is connected to the reservoir and is blocked by the handlebar mount. Is there another way or are clip-ons my only solution?
looked for pics but didnt have any. |
January 20th, 2011, 04:46 AM | #2 |
January 20th, 2011, 04:49 AM | #3 |
^^^Thanks Sean!
January 20th, 2011, 09:03 AM | #4 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
You can move it down. Just losen the two 8mm bolts and ajust it where you want it. Thats what I did when I had my OEM hadles.
January 20th, 2011, 10:31 AM | #5 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
If your having to rotate it down more then when the reservoir hits the handlebar mount, then your sitting way to far forward on the bars, or riding with your arms extended almost straight down. Try sitting back so your forearms are more parallel with the ground as well as loosening up at your elbows. That will flatten out your wrist more and put the brake lever more in line with the palm of your hand, which is where you want it.
Keep in mind also, that by rotating the reservoir that far, your creating an open void close to the fluid intake in the master cylinder and are more likely to draw in air.
2009 KLE650 LSL bars, Full Muzzy PC-V 1995 900SS/CR mildly modified |
January 20th, 2011, 12:25 PM | #6 | |
bubble in the front brake reservoir | yogurtpooh | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 10th, 2015 04:38 AM |
Screws for front brake fluid reservoir | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 29th, 2014 09:33 AM |
Leaky Front Brake Reservoir | NicoleH28 | 2008 - 2012 Ninja 250R Tech Talk | 26 | June 3rd, 2011 09:26 AM |
front brake reservoir socks | zilaniz | General Motorcycling Discussion | 27 | February 8th, 2011 05:40 PM |
