Old April 1st, 2013, 11:01 AM   #1
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
Kickstand switch removal
I would like to remove the kick stand switch off of my pre-gen. I keep having to take my kick stand off at track days so that I don't drag it. That leaves the kick stand stitch dangling. I keep zip-tying it to the fairing bracket but it's not a very robust solution. It's also a pain in the butt! I'd like to just remove the switch all together. Do I need to jump any wires to delete the switch? Or can I just cut it off?
cookiebug79 is offline   Reply With Quote
Old April 1st, 2013, 11:13 AM   #2
lgk
not sure about the old gen but the new gen just needs the wires connected.
Old April 1st, 2013, 11:19 AM   #3
cut it off and tape it up, then remove the neutral sensor (single wire plug near the output shaft) so the bike thinks its always in neutral, then remove the gauges so you don't have to see that ugly neutral light. i black tape the neutral light
Old April 1st, 2013, 11:49 AM   #4
cookiebug79
n00b with the b00bs
OK, so if I cut it off, do I need to connect the wires or keep them separate? And if I connect then do they need resistor?
Old April 1st, 2013, 11:57 AM   #5
lgk
i just cut it between the plug and kick stand sensor, and soldered the wires together.
i didn't get a chance to measure the resistance of the switch, it was trashed from my crash.
Old April 1st, 2013, 04:04 PM   #6
cookiebug79
n00b with the b00bs
sweet. thank you!
Old April 1st, 2013, 06:03 PM   #7
Yes, the wires need to be solidly connected; if they get disconnected, the spark plugs will not fire.
No resistor is needed.
It is a safety device, replace it if you replace the side stand.
http://faq.ninja250.org/wiki/Underst..._how_they_work
Old April 3rd, 2013, 02:49 PM   #8
cookiebug79
n00b with the b00bs
Thanks everybody! Just to close the loop on this (Ha! So punny...)
I followed the wires from the switch and they led to 2 pigtail connectors:
I unplugged them both and plugged the male end of one into the female end of the other. And it worked! Kickstand switch delete complete!
Old April 3rd, 2013, 04:04 PM   #9
thats convenient. new gen doesnt have that i think.
Old April 3rd, 2013, 06:37 PM   #10
lgk
New gens have a two pin connector instead of the singles
Kickstand Kill switch - Inert omarcarbomb 1986 - 2007 Ninja 250R Tech Talk 10 March 13th, 2015 12:45 PM
Frozen Kickstand Kill Switch? Brother Michigan 2013 - 2017 Ninja 300 Tech Talk 8 January 9th, 2014 12:59 PM
1985 zx900 a-2 ignition switch removal justen General Motorcycling Discussion 2 May 27th, 2013 10:02 PM
Ignition switch removal rkildu 1986 - 2007 Ninja 250R Tech Talk 2 June 1st, 2012 03:48 PM
Kickstand safety kill switch removal? paterick4o8 2008 - 2012 Ninja 250R Tech Talk 9 July 17th, 2009 12:05 PM
