Old July 12th, 2014, 12:54 PM   #1
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
Racebike build mod list
So I finally got around to making a full list of all the stuff done to my bike, enjoy!
--Engine:
'09 with Stock internals and airbox as required by rules
Area P high flow race system with 18" carbon can
BMC Air Filter
Dynojet needles, factory Keihin jets
KG Factory Kevlar clutch plates, OEM steels
Kreiger manual cam chain tensioner
NGK CR8EK spark plugs
PSR smog block off plate
Radiator fan removed
Thermostat removed
Thermoswitch replaced with plug
Aluminum magnetic drain plugs
Motorex Crosspower 4t 10w50
--Suspension, Drive and Brakes:
Ohlins shock w/ carbon reservoir bracket
Titanium shock mount bolts, KTM leftovers
Race Tech cartridge emulators
Race Tech .80 fork springs
Motorex 15wt fork oil
All Balls tapered roller steering head bearings
SSR adjustable preload fork caps
Braking SK2 floating front rotor
Galfer direct thread-into-the-caliper front brake line
Galfer steel rear brake line
Aluminum banjo bolts
EBC HH pads
Motul RBF brake fluid
Captive rear brake hanger mod
"Oaksterdam" rear rotor, thanks rojoracing53!
Graves rear brake lever return spring kit
Driven sprockets 14-42
Regina chain
--Chassis and Controls:
Woodcraft clipons
Renthal road race grips 32mm
Woodcraft rearsets
Yamaha TW200 shift lever
G2 Ergonomics perch spacer for front master cyl
Cycle Pirates billet race throttle kit
CRG Roll-a-Click knockoff levers
KTM Powerparts front brake lever guard
Media blasted clutch perch
ZETA rotating perch clamp on master cyl
Yoshimura aluminum stem bolt
SSR race fuel cap
Orange powdercoated frame
Shogun framesliders
Custom adjustable steering stop bolts
Custom in house made ultra light fairing bracket
Hotbodies bodywork and windscreen
Motoseat seat cover
Worldwide ceramic wheel bearings
Custom shortened choke cable, near carbs now
--Electrics:
Trail Tech Stealth Vapor gauge with all functions active
Custom in house made carbon dash panel
Custom oil pressure warning lamp
Custom in house made race wire harness
Toggle ignition switch
Shorai battery
K&S start/stop/run switch
Race team facebook page: https://www.facebook.com/TeamTreeTrees
Build video link: http://youtu.be/FyJBYJz5SSQ?t=29s
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
Last futzed with by smokinsingle; July 24th, 2014 at 06:12 PM.
smokinsingle is offline   Reply With Quote
Old July 14th, 2014, 10:23 AM   #2
Old July 22nd, 2014, 02:16 AM   #3
SouthHalfrican
Motorcycle(s): Ninja '07 250, '03 500, Ducati '01 M750, '03 999 base, 1198S corse, Honda 77CB750F2
That thing is ludicrous.
SouthHalfrican is offline   Reply With Quote
Old July 22nd, 2014, 07:48 AM   #4
Worldtraveller
Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F
What he said. I don't think some of those mods are legal in the classes I'm racing, but I'd love to compare that to my mostly stock bike for the difference in feel!
I haven't even re-jetted mine yet...
Worldtraveller is offline   Reply With Quote
Old July 24th, 2014, 10:27 AM   #5
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
That is beautiful. brb need new panties
Xtina is offline   Reply With Quote
Old July 24th, 2014, 11:41 AM   #6
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
whats your thoughts on the ceramic wheel bearings
Old July 24th, 2014, 05:45 PM   #7
smokinsingle
L8APEX
Dunno, I guess I don't notice a whole lot of difference compared to my other pit buddies with out them. Then again the only comparison I have is spinning it with my hand on the stands. I think there is way more to gain by lowering chain and brake friction first.
Old July 24th, 2014, 06:27 PM   #8
sharky nrk
sharky nrk's Avatar
^^^ cool, thanks for the honest info
Old August 9th, 2014, 09:41 AM   #9
mgentz
Board Member
Sweet bike.
Old August 9th, 2014, 11:02 AM   #10
Baron
Urban Legend
Baron's Avatar
Motorcycle(s): 09 Ninja 250R SE - Circe
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up."
-Baron
Baron is offline   Reply With Quote
[sportrider - features] - Kawasaki ZX-6R Racebike Build | Ready or Not Ninjette Newsbot Motorcycling News 0 August 20th, 2014 02:40 PM
[sportrider - features] - Kawasaki ZX-6R Racebike Build | Crunch Time Ninjette Newsbot Motorcycling News 0 June 24th, 2014 02:56 PM
[sportrider - features] - Kawasaki ZX-6R Racebike Build | Seeing Green Ninjette Newsbot Motorcycling News 0 June 16th, 2014 08:40 PM
96 Pre Gen Racebike Build Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 32 December 23rd, 2013 01:41 PM
[sportrider - latest stories] - Kawasaki Ninja 650 Racebike Build | Green Streak Ninjette Newsbot Motorcycling News 0 March 22nd, 2013 12:30 PM
