August 16th, 2014, 11:44 PM | #6001 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Finished the seats on my sex r
Cleaned the carb on the klx.
August 17th, 2014, 05:31 PM | #6002 |
I got the motor fired up but it looks like I have some carb issues... Bike needs choke to start and dies without it. If I keep the throttle open and close the choke the bike bogs and I smell unburned fuel out the exhaust. I let off the throttle and it dies. Time to pull the carbs again.
August 17th, 2014, 06:22 PM | #6003 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
Gave her a good wash after finishing the install of my Galfer SS lines.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
August 17th, 2014, 08:52 PM | #6004 | |
#squid
MOTM - Jul '16
August 18th, 2014, 02:54 PM | #6005 |
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... Last futzed with by LittleRedNinjette; August 18th, 2014 at 04:20 PM. |
August 18th, 2014, 06:14 PM | #6006 |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
Rebuild the front master cylinder (kind of a waste of money, piston assembly looked fine), installed speed bleeders and had some fun flushing brake fluid without any effort for once.
August 18th, 2014, 06:51 PM | #6007 |
MOTM - Jan '18, Sep '13
Finally put the front brake caliper back on and bled the brakes a bit more for good measure. Still feels mushy though so I ziptied the lever down and will check back on it later tonight. I noticed this being an annoying problem before when I changed to SS lines. I was able to get rock solid brakes when I swapped lines on a 250 though. Are ABS brakes doomed to feel a little mushier than a bike without ABS or is there a trick to it?
August 18th, 2014, 07:01 PM | #6008 |
Clogged pilot jets. I couldn't even see through them. I gave the carbs a real thorough cleaning seeing how I got leftover rust clogging the pilots. I also pulled the spark plugs and aired out the cylinders since I flooded them trying to start it again.
Hm. I don't think this is suppose to be removed at all.
August 18th, 2014, 07:03 PM | #6009 | |
August 18th, 2014, 11:40 PM | #6010 |
Ok I guess the zip-tie trick worked. Brake feels firm. I'll go take it for a ride tomorrow.
August 19th, 2014, 12:39 PM | #6011 |
Fast-Guy wannabe
MOTM - Jan '13
After bump starting my bike over a dozen times this month I finally installed the new battery I bought over a year ago. Yeah its nice to be tall enough to bump start a motorcycle on your own even on flat ground. Just realized its for the 2008 model so its a bit smaller then the 2009-2012 hope it still cranks the bike for a few years. 135cca vs 110cca may come into play down the road.
August 19th, 2014, 01:17 PM | #6012 |
Join Date: May 2014 Motorcycle(s): 99 Ninja 250 Posts: 217
Just placed and order on partzilla for a k&n oil filter, clutch cover gasket, and starter cover gasket. Have a lot of work ahead of me on the bike. Anyone want to come over and have a bike working party.
Everything you’ve ever wanted is on the other side of fear. –George Addair |
August 19th, 2014, 03:06 PM | #6013 | ||
If you ever cheap out, gasket maker works fine too.
August 19th, 2014, 03:28 PM | #6014 |
Yeah I have gasket maker in the tool box but I do not mind spending a few dollars for replacement gaskets. Thanks for the info.
August 19th, 2014, 06:24 PM | #6015 |
My bike does not seem to like the stock exhaust but it seems to like the straight pipe! LOL. I need to make an exhaust or find one dirt cheap.
August 19th, 2014, 06:49 PM | #6016 |
#squid
MOTM - Jul '16
Cleaned her for the 3rd time in a week and lubed the chain for the third time.
August 20th, 2014, 06:04 PM | #6017 |
Working on wiring my chinese Thor motorcycle alarm. Right now the bike can be started but the alarm will kick on and kill the bike. Not sure if I wired it right yet.
August 20th, 2014, 11:44 PM | #6018 |
#squid
MOTM - Jul '16
Used up some of the tire life in twisties. Rode it home in the pouring rain after work later.
August 21st, 2014, 07:18 AM | #6019 |
dirty boy
MOTM - Apr '14
Other than ride it to work nothing and it feels great! The bike is running stellar, better than it ever has, I have no plans of doing any mods to it in the near future.
Smooth sailing from here on out, nothing but lubing some stuff here and there, changing oil, keeping up on general wear and tear.
August 21st, 2014, 07:32 AM | #6020 |
Fighting Texas Aggie '05
commute commute commute on the Ninjette
I did get my ignition delete done on the F2/F3 the other day. Man I need to get that bike out on the track but the 250 has been keeping me so entertained.
August 22nd, 2014, 06:22 AM | #6021 |
Certified looney toon
MOTM Jul '13, Jul '14
Yesterday, picked up the bike after her service and marveled at the shiny new Galfer brake lines. Straight up stainless steel, no special colors for the lines or banjo bolts. Pretty!
Went for a ride.... So I went to pull over into a dirt turnoff on the side of a paved road to grab a picture of the canyon I was riding down. Guess the bike decided since I was going to take a short break, she should too. I really hate seeing my wheels anywhere except on the ground. (Pavement had a lip that the sun angle camouflaged. As soon as the front tire crossed over, the bump down threw off my balance and I couldn't hold the bike up. Fark! And the freaking flush mount popped a hole in my fairing! WTH?!?)
August 22nd, 2014, 07:16 AM | #6022 |
Join Date: May 2013 Motorcycle(s): 10 Ninja 250 Posts: 172
Plasti dipped the wheels white. I think it looks super sexy. So i'm going to get them powdercoated white in the future.
And I MIGHT plastidip the plastic trim under the seats white to see what it looks like... |
August 22nd, 2014, 07:18 AM | #6023 |
^^ Looks good!
August 22nd, 2014, 07:56 AM | #6024 | |
one thing I am always curious about is any "soft damage" like paint marring or swirling you get from using it
August 22nd, 2014, 08:01 AM | #6025 |
Red 250's with white wheels are the sh*t!
White wheels require a bit of preemptive cleaning to keep looking snazzy. Hope the plastidip holds up well for ya.
August 22nd, 2014, 08:11 AM | #6026 | |
MOTM - Sep '14
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
August 22nd, 2014, 09:31 AM | #6027 | |
I have dipped my car wheels red on my winter wheels. By the beginning of the spring its kind of baked on there, so its hard to peel. Almost like peeling your skin after a sunburn. Sometimes youll get big chunks, sometimes its a bastard and youll get teeny tiny pieces and it will take forever. However, you can get it off better by putting on another coat. I'm going to paint the plastic trim now because I have the day off and I'm bored. Ill post a pic when im done. |
August 22nd, 2014, 05:55 PM | #6028 | |
@NevadaWolf
August 22nd, 2014, 06:12 PM | #6029 |
But but.... we did hang it on the 250 peg...
I know I had a couple beers but still...
August 22nd, 2014, 06:19 PM | #6030 |
Maybe I need to drink some too and tackle this again lol
August 22nd, 2014, 06:24 PM | #6031 |
Haha, maybe.
August 22nd, 2014, 06:58 PM | #6032 |
August 22nd, 2014, 10:12 PM | #6033 |
300 pipe, 250 peg
August 22nd, 2014, 10:13 PM | #6034 |
Nice and sparkly there Mrs. Red.
August 23rd, 2014, 01:32 AM | #6035 |
Can't wait to see it in the sun.
August 23rd, 2014, 03:45 AM | #6036 |
#squid
MOTM - Jul '16
Mastered my chain maintenance. No longer flings at all, and the chain is still sticky after a ride in the rain. No caked on grime either.
hooray for maxima and bel-ray
August 23rd, 2014, 05:37 PM | #6037 |
Popped on a new rear Diablo Rosso II. Hope to break it in tomorrow morning...
August 23rd, 2014, 06:46 PM | #6038 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Replaced my flat spotted, quad dinged front wheel with a near mint condition wheel, OMG i forgot how nice it is to have a perfectly round wheel again.
August 24th, 2014, 06:44 PM | #6039 |
yes, I'm famous.
Join Date: Nov 2012 Motorcycle(s): 2009 Ninjette 250R Posts: 80
Used liquid tape to waterproof wires to my LED strips, replaced spark plugs, searched for the source of a mysterious rattling sound I hear at 9+ rpm... No luck finding it
I cant wheelie and that makes me sad. |
August 24th, 2014, 07:13 PM | #6040 |
Wrench wench
Stuck on some vanguard 3M protective film on the sidecovers of the pregen. Dunno if anyone else has had my experience, but my boots completely wrecked the clearcoat and decal near the peg on the sidecover. Wish I put the film on before that started happening...
Also, got rid of the awful wobbly loose-as-hell ebay adjustable/extendable/folding brake lever in favour of the stock one. Lever feel is like a thousand times better. |
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
