May 26th, 2010, 06:41 PM | #41 |
You are sleeping
New front wheel cowl installed.
Really helps the front end stand out quite a bit. Here is the one it came with, all painted and chopped short The new one has the brake hose clip still mounted and no cracks in the plastic. You can really see how much they trimmed off in this pic.
<Yeah, it's a 250. LMFAO! Weaksauce |
May 27th, 2010, 05:01 PM | #42 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
f*in awesome!
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
May 27th, 2010, 06:35 PM | #43 |
2012 is here,let's ride!!
Join Date: Sep 2009 Motorcycle(s): 2009R,'12 suzuki +500 Posts: 354
bike lookin good ,kc getting lucky findin those oem parts.
May 28th, 2010, 01:42 AM | #44 |
You are sleeping
Thanks guys.
I had something for sale on ebay but it didn't sell. Gonna have to wait a short while longer on my brake rotors and pads. Still waiting on some more plastic too though. She's slowly getting better. Much nicer now than when I bought it. To be continued in a short while when I get more parts. Time to work on the ninja again for a little bit. I have to remember to adjust the steering stem nut and steering play again though. These old gsxr's always have play in the headset. One night I gotta sit down and figure out how to get rid of it once and for all. I always adjust the steering nut but not tight enough and it loosens up just enough to create play after a few miles again. Next time I'll have to crank it down another half turn more after I "think" it's tight. Steering play is annoying. Then you have to get on the bike and test it to make sure it still turns. If it's too tight the bike gets all hard to turn on you. lol
May 28th, 2010, 02:59 PM | #45 |
MOTM - Mar '13, Jun '14
If you are looking for an inverted front end I saw one on the Wera forum this morning. Would really make the bike extra groovey.
May 28th, 2010, 06:05 PM | #46 |
You are sleeping
Eh I'm gonna sell her in a year or so for a new one I think. When she's spanking new then I'll go for upgrades. For now - wokring on getting it back to stock. lol
I spent all day today (birthday) adjusting the damn steering stem nut 3 times and testing between each adjustment. Hell of a long day but got out for a small twisty run and a couple wheelies again. (see new avatar) Here's some pics of the stem nut adjustment. Repeat x3. lol Still think I could go tighter! Needs more work man. Steering play is my pet peeve.
May 29th, 2010, 02:55 PM | #47 |
IC2(SW)
Dam, your doing allot of work to that bike! It's looking real nice
May 30th, 2010, 07:43 PM | #48 |
You are sleeping
Just added the icing on the cake.
Nice new Bremzen rotors on the way. Paid full price for the 100% USA made non knockoff ones. Let's hope they're right. Now I need pads and lines. Front suspension on this thing is so stiff, pretty sure I can leave it as it is. I want one of those Galfer floating rear rotors. Did get the headset play finished up today too. Now it's a tiny bit on the tight side and should seat up after a nice freeway ride.
May 30th, 2010, 08:22 PM | #49 |
Wow! This is a very cool project. It's great to see fully restored classic sport bikes. Yours is turning out very nice.
May 30th, 2010, 10:07 PM | #50 |
RedNinja09
Wow, I really enjoyed reading your posts about all the work you are putting into the Suzuki. Very interesting. I totally agree that you shouldnt buy used unless you are a mechanic. You never do know what people have done.
This is my 2nd summer riding my 2009 Ninja. Any tips on what I need to do to maintain it ? I suppose I could get out my owners manual buuut... I am no mechanic. I would have to take it in somewhere for service. But, any tips from a pro would be appreciated. Red
Chris |
May 31st, 2010, 02:39 AM | #51 | |
You are sleeping
Thanks for the kind comments guys.
Really just throwing money at it. That's all there is to it. That and a little elbow grease and the right tools for the jobs. (I need a headset adjusting wrench badly for my bikes! I'm chewing the bolt up with pliers getting it adjusted properly) No toolmarks or you got the wrong tools! Quote:
Sometimes I just take stuff apart on my bike for the fun of it, or to completely clean a part for no reason and put it back on. That's how I spot loose bolts before they come lose and fall out etc. I pretty much mean every bolt on the motorcycle. Yep, I have touched all of the structural bolts on my bike with a socket and torque wrench at least once, where applicable. I had to redo the steering play on the gsxr 6 times before I finally got it right yesterday and even then I still might be a *hair* too tight and have to do it one more time. lol. This took me like 3-4 days and a lot of patience because I had to test ride it between each adjustment which meant disassembly and reassembly between each test ride. Inspect your tires for nails or cracks too and frequently check your tire pressure. Make sure you battery cables are connected well and all your lights work and the brake light actuators are adjusted right. Might even add a bAttery tender if you have not already. Measure the stretch in your chain and compare to the service manual. also check for sprocket wear, and lube the whole final drive. Might even give a quick visual check of your brake rotors and pads. You can usually see when they need to be replaced just by leaning over and looking at the calipers/pads/rotors. Also retorque your caliper mounting bolts front and rear while you are at it. (safety measure) The best thing you can do is make sure the bike is sound and running like it should by making sure it's not falling apart all the way down to the suspension and engine bolts. Then you know for sure you are the only one to blame when something goes haywire! start pulling plastic off 'till she's naked and start picking bolts to tighten! When you're done with each one, mark it with a paint marker and move to the next one! when your done, the piece of mind you have about riding your bike that it is assembled correctly will be rewarding and give confidence enough to ride hard and do your own maintenance from then on.
May 31st, 2010, 12:05 PM | #52 |
RedNinja09
OK, I always do a visual check of everything before I go. Just a once over to make sure everything looks right. But, that's about as far as I go mechanically. I dont know anything. But, I will keep that info in mind....
Chris |
May 31st, 2010, 02:07 PM | #53 |
Join Date: Dec 2009 Motorcycle(s): "Is that a Ninjer 1000?" Posts: A lot.
Daammmm--your bike looks waaaaayy different since I last saw it~~!! Nice freakin job dude!
Chris--believe it or not KC is a mastermind mechanic....he took my fairings off in 2 minutes flat~ KC- I've got my hmf slip on exhaust coming...my left signal ....going to get the oil...filter....and so on....can't wait to hit Palomar---I'm off June 8th for summer vacation!!!!!!!! |
May 31st, 2010, 09:38 PM | #54 |
RedNinja09
I believe he IS the master mechanic. Looking at all that work, he has to know what he is doing. I wish he lived around the corner from me. Damn it...
Chris |
June 1st, 2010, 02:47 AM | #55 |
You are sleeping
I'm no special person. Just played with legos as a kid growing up.
I believe it makes the difference. lol I also learn exceptionally fast. I forgot to add, check all your fluids.. and chain tension. Let me know when you get your goods Adrian. I'll help you out no probs. You know my number. Hit me up if I go missing from the site. I probably won't be welcome on this site anymore because I grow annoyed with answering to grumpy old guys about everything I say. If I'm so controversial, half of what I say must be worth something.
June 1st, 2010, 06:25 PM | #56 |
Don't you know that the grumpy old men on this forum sit around all day waiting for you to post.....it's their livelyhood and if you go--what will they do? Maybe croak sooner???
June 1st, 2010, 06:49 PM | #57 |
How is CC a grumpy old man when he suggested where an inverted fork could be found for the gsxr?
June 1st, 2010, 07:10 PM | #58 |
1st warning.
June 1st, 2010, 07:13 PM | #59 |
ya know.. I read adri99an's reply like 5 times and I don't get it.....
June 1st, 2010, 07:17 PM | #60 |
My exhaust should be here in a few days....my left blinker as well....what oil should I pick up at Berts? And how much of it? Also....got back from Azusa Canyon a bit ago and noticed my rears were squeeeking.....someone mention not to go HH in the rears because they seem to lock up...is this true?
June 1st, 2010, 07:22 PM | #61 |
[visordown.com] - Suzi Perry voted as dream pillion | Ninjette Newsbot | Motorcycling News | 0 | August 4th, 2011 01:40 PM |
[visordown.com] - Suzi Perry warns bikers to protect their hearing | Ninjette Newsbot | Motorcycling News | 0 | July 12th, 2011 08:50 AM |
[visordown.com] - Suzi Perry backs National Motorcycle Week | Ninjette Newsbot | Motorcycling News | 0 | July 8th, 2010 12:50 PM |
[MotoGP News] - Suzi Perry given the axe by the BBC | Ninjette Newsbot | Motorcycling News | 0 | March 16th, 2010 03:10 PM |
[visordown.com] - Suzi Perry's biker game is iPhone's most popular | Ninjette Newsbot | Motorcycling News | 0 | October 14th, 2009 05:30 PM |
