September 4th, 2011, 05:59 PM | #1 |
air filter question
Hey guys has anyone used the uni air filter? I was wondering if it is any good. Or should I just go with a k&n?
Thanks guys |
September 4th, 2011, 06:02 PM | #2 |
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R SE (Green) Previous bikes R1, Daytona 675, GSXR600, Pre-Gen 250R Posts: 330
I'd say stick with the K&N or BMC. They are the tops.
'11 Green SE - 2 Bros Blk Series CF, Factory Pro Jet Kit, Spiegler Lines, ZG Windscreen, Pazzo Levers, CW Fender Elim, Custom LED Integrated Tail Light, Protons, OEM Seat Cowl & Ti ProBolts. |
September 4th, 2011, 07:29 PM | #4 |
They are different filters. BMC & K&N are gauze type filters while the Pipercross is a 3 layer foam filter. It has been proven the foam filters breathe better and are easier to clean. From what I've seen the BMC & K&N are clean and lubed similar and can be a PITA. The BMC & K&N drop in type filters have rubber around them while the Pipercross resembles the stock filter (uses the stock filter frame) and is also cheaper than the other two.
Also Pipercross is a Official partner for the 250 & 600 Ninja Trophy http://blog.pipercross.net/?p=304 (Oh, and the picture on their package is none other than a Kawasaki.) I wrote Pipercross to find out if they had any data for the Ninja 250. They did not, but they said there is a Kawasaki race team that has done the testing and is using them in their race bikes. My thought is; "Why would any Kawasaki race team run an aftermarket filter if it does not help performance?" However they do have data for other bikes which I have not seen any for the other air filter brands. http://www.pipercross.net/motorcycle/products.asp http://www.ninjette.org/wiki/Air_filters_for_newgens http://www.ninja250forum.com/index.p...26046#msg26046 http://www.calsportbike.com/px/ |
September 4th, 2011, 07:33 PM | #5 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
I have uni pod filters on mine.. no complaints here.
#1 |
Air filter question | Joshua95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 2nd, 2014 03:00 PM |
Pipercross air filter question | dmb5450 | 2008 - 2012 Ninja 250R Tech Talk | 7 | December 26th, 2012 02:02 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Anyone know an air filter I can replace the OEM filter with? | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 22nd, 2012 09:34 AM |
Air Filter Box Question | Little Green Machine | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 14th, 2012 06:25 AM |
