Old March 23rd, 2012, 03:47 PM   #1
Zyconic17
Motorcycle(s): 2010 Ninja 250r Track bike, Honda CRF250r Dirt bike
Possible Tire Wear Issue?
So here is the story, i got a brand new set of Bridgestone BT-003RS's for my race bike and took them to the track. I finally got the chance to use the tire warmers that day so it was the first time i had ever used the warmers. I ran pretty hard all day and kept alot of heat in the tires so they were pretty much a consistent temp all day. The pressures i ran were 28/28 HOT. At the end of the day i looked at the tires and saw that they had worn fairly even but there is a strange line about an inch from both edges of the rear tire... it connects all of the tips of the tread grooves all the way around the circumference of the tire. I heard that this may be known as a hot tear? If this is normal and im just paranoid please let me know, but if not... id like to make changes to the setup of the bike so that the tires wear in the most ideal manner. thanks!
Zyconic17 is offline   Reply With Quote
Old March 23rd, 2012, 04:57 PM   #2
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
I believe you are seeing the transition from one rubber hardness to the other. If I remember, the 003RS are triple-compound tires. Its normal, and I've seen it on my Aprilia RS250 running those tires. BTW, 28/28 hot is pretty low.... I'd try 28/28 cold.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old March 23rd, 2012, 05:13 PM   #3
cuong-nutz
cuong-nutz's Avatar
It does look like a compound change. I know they are very noticeable on my BT-016s
HalfFast Racing Team
Old March 23rd, 2012, 05:23 PM   #4
Zyconic17
Alright thanks! i knew about the triple compound... i just didnt think it would start at the very edge!
Old March 23rd, 2012, 05:48 PM   #5
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
yep totally normal, thats the stickiest of the icky right there. From the look of it though, you're not getting enough heat into the rear tire... I used to run the bstone 24psi cold 27 psi hot. Or just go faster.
Actually just switch to the pirellis.
Rexbo is offline   Reply With Quote
Old March 23rd, 2012, 07:12 PM   #6
Zyconic17
You are probably right about me not getting enough heat in the tires....haha im still a noob and barely have any track time under my belt. And from the way you have been bragging about those pirelli's i may have to give'em a try!
Old March 23rd, 2012, 09:07 PM   #7
randy328
CMRA Mini Endurance #6
randy328's Avatar
Motorcycle(s): CBR954, CBR600RR, EX250
We run the Stones at 29F/26R hot and they work well for us.
CMRA #328
Ridesmart.info Instructor
randy328 is offline   Reply With Quote
Tire wear article subxero General Motorcycling Discussion 7 February 26th, 2014 07:57 AM
tire wear life for fat people pb3 2008 - 2012 Ninja 250R Tech Talk 22 October 28th, 2012 04:11 PM
BT-16 tire wear cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 2 April 17th, 2012 09:04 PM
Chicken strips and uneven tire wear? Raybot 1986 - 2007 Ninja 250R Tech Talk 6 October 13th, 2010 11:41 AM
What do you think of my tire wear? headshrink 2008 - 2012 Ninja 250R Tech Talk 13 May 27th, 2009 04:51 PM
