September 3rd, 2012, 09:39 PM | #1 |
time is running out....
Join Date: Sep 2012 Motorcycle(s): pregen ninjari Posts: 412
swingarm conversion. from an 04 to 08
I hear there's a lot of people out there that converted the 88-07 pregen 250 ninja rear swing arm to the newer 2008 ones that were aluminum n alllowd the 17" wheel......I found a swing arm and wheel. but what other part will I need? as in what other 2008 parts will I need? id like to use all the parts I can that I already hav.
September 3rd, 2012, 09:49 PM | #2 |
So far, there's been 1 guy who's gone through the whole conversion with the front and back from an '08
http://www.ninjette.org/forums/showp...3&postcount=19 But there are racers who have found ways to fit the 08+ wheels in the 88-07 swingarm and forks with some other custom made pieces to get the brake calipers lined up and wheels spaced properly etc. I forget which thread that's in, but use the search bar and it shouldn't take too long to find. If you do the conversion with one end, do the other end as well. No use having a nice 17" sticky radial tire on one end and a 16" bias ply on the other, plus that would look dumb. |
Planning a NewGen swingarm conversion | lolibater | 1986 - 2007 Ninja 250R Tech Talk | 32 | May 25th, 2024 04:47 AM |
My streetfighter conversion | jenkem | 1986 - 2007 Ninja 250R Tech Talk | 57 | July 13th, 2015 09:33 AM |
Conversion Into A two Piece. | krolinked | Motorcycle Gear | 12 | June 20th, 2012 08:32 PM |
Projector conversion | ninjagaiden09 | Pictures | 11 | May 7th, 2012 07:51 PM |
Conversion to trackbike | 08ninja250 | Ninjettes At Speed | 8 | September 8th, 2010 05:03 PM |
