Old August 28th, 2023, 06:00 AM   #1
Milkyfitzy
Milkyfitzy's Avatar
Motorcycle(s): 2006 ninja 636
No power to bike
Hey, i own a 2006 ninja 636 and i cant get power. I’ve blown my fuse three times now ( 30a ). The fuse blows when i turn the bike to ( on ) position. I cant seem to find the ground location, or a diagram showing me where it is. I’m assuming it has something to do with the ground but i’m not 100% sure.
The three times it happened was leaving a stop light ( once in first gear just leaving, other two times shifting to 2nd ). If anyone can help that would be appreciated greatly. I miss riding my baby 😭😭
Milkyfitzy is offline   Reply With Quote
Old August 28th, 2023, 06:38 AM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Most likely you have a short to ground where a wire has rubbed through the insulation and exposed the bare wire. If its happening intermittently, it could be something that is only rubbing (and now grounding) occasionally.
My race bike had a similar issue where the hydraulic hose rubbed on the wire harness under full compression, eventually blowing the fuse on track.
Old August 28th, 2023, 07:28 AM   #3
Milkyfitzy
Milkyfitzy's Avatar
So it could be any wire blowing the 30a main power? Where do you suggest i start? Im not very electrically inclined so im trying to gather as much info as possible before i start taking things apart.
Old August 28th, 2023, 07:37 AM   #4
It's most likely not one of the smaller wires on a circuit protected by a lower current fuse. Start with the wires on the non-battery side of that 30A fuse.
Old August 29th, 2023, 08:47 AM   #5
What's history behind this bike?
Any non-stock mods?
When was last time it worked perfectly?
What happened between then and now?
Old August 29th, 2023, 09:22 PM   #6
Milkyfitzy
Milkyfitzy's Avatar
The bike has a full two brothers exhaust system, and two LED &HID lights.
About a month and a half my side fairing flew off, ripping the led light system out.
Everything looks ok for the wiring there.
I had a clutch cable replaced over a month ago also.
Old August 30th, 2023, 09:16 AM   #7
Unless you are Superman and can see electrons moving inside wires, there's absolutely ZERO way any human can look at wires and determine its ability to conduct electricity. Luckily, we have instruments that can.
1. get multimeter: https://www.harborfreight.com/7-func...ter-63759.html
2. learn how to use it to measure voltage and resistance: https://learn.sparkfun.com/tutorials...multimeter/all
3. first-step is to remove all remnants of LED light system that wasn't ripped out. Most likely shreds of this wiring is connected improperly between power & ground causing short. Such as bare wires touching frame. Restore harness back to 100% bone-stock configuration. Because it worked perfectly fine when leaving factory and showroom floor, we want it back to that state 1st to get bike working.
Remove all crimps and additional wires added. Only factory wires remaining. Cover any exposed wires in harness with good electrical tape.
4. That is just start and may not work because of alterations to harness. Next, we can measure various points on harness. And from numbers we can figure out exactly what's wrong and how to fix it.
OR
What lots of people do is just swap parts without ever finding actual fault. Requires replacing LOTS of perfectly-working parts with brand-new perfectly-working parts and nothing changes. But after their 100th parts-swap, they may luck out and randomly replace actual bad part without ever knowing what it was. Start with:
- main harness https://www.ronayers.com/oemparts/p/...7/harness-main
- battery cable+ https://www.ronayers.com/oemparts/p/...e-lead-battery
- battery cable- https://www.ronayers.com/oemparts/p/...e-lead-battery
https://www.ronayers.com/oemparts/a/...ical-equipment
Last futzed with by DannoXYZ; August 30th, 2023 at 11:00 AM.
Old August 31st, 2023, 08:11 AM   #8
Milkyfitzy
Milkyfitzy's Avatar
Hey thanks alot for the reply, i’ve used a multi meter and everything seems good with that (13v)
Old September 11th, 2023, 05:22 AM   #9
Apex
Livin' the Minimoto Life
Apex's Avatar
Before I dive into electronics troubleshooting, what does that 30A fuse do exactly?
Old September 11th, 2023, 05:33 AM   #10
It supplies power to everything except the starter motor, which is connected directly to the battery when appropriate. If the 30A fuse blows, no other fuse gets power.
Old September 15th, 2023, 04:12 PM   #11
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
in this case I would pull on the wireing harnis enough to get it away from the frame and twist it so you can see the underside that was touching the frame this is where you get wires exposed and short out if you find an area like that Repair it properly and use good insulation for the wires so it will never happen again. if all you have is black tape to repair it with then use a whole bunch so it can't rub through again.... most bikes will have a area that is prone to short out the wiring harness believe it or not ! this isn't a one off problem,... it happens all the time...
the problem with using a meter on intermittent shorts is when your trying to find it
everything is good no shorts, the short only shows up when you hit a bump or turn the handle bars a certain way .... I am guessing because it shorted out when you shifted into 2nd 2 times that it is located near the engine under the seat , just a wild guess I assure you.....but that is where I'ed look... that in the headlight area as that is notorious for problems in all bikes
what your looking for is hard to find.... a wire that has the insulation wore down on one side and the copper wire inside the wire is exposed I've found shorts like that many times behind the headlight in older bikes and by the rear fender and tail light
I think your only hope at finding an intermittent short is to remove all the fairing **** and get down to the actual bike then start your looking intently on the main wiring harness.... if you find nothing then move to the smaller branches of the wiring harness
checking them the full length.... be diligent around any areas that are around hot things like engine head or exhaust pipe....
the big wire that goes to the starter motor is controled by a relay but the relay is powered by alot of battery power.... and usually runs on the 30 amp circuit.....
so check the wire from the battery to that starter relay and just make sure there are no bare spots in it...
this is one of those " hunt until you find it" things.... there is no easy way !
Bob......
[motorcycle.com] - Simple USB Power For Your Bike Ninjette Newsbot Motorcycling News 0 October 24th, 2016 04:00 PM
Bike lost power this morning SafetyPaws 2008 - 2012 Ninja 250R Tech Talk 3 June 30th, 2015 06:09 AM
No power to bike joeybaila 2008 - 2012 Ninja 250R Tech Talk 3 February 6th, 2015 07:12 PM
Power Commander for new bike? dive1tom General Motorcycling Discussion 5 December 8th, 2009 08:53 PM
Help me buy a bike with less power 00v_Lucky Off-Topic 6 April 21st, 2009 05:12 AM
