Old November 5th, 2012, 09:42 PM   #1
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Ok hopefully someone can answer this one...(speedometer harness wiring diagram!)
Hey guys, so i bought this new gauge and it finally came in, does any one know of a diagram that shows what color wire on the harness goes with what. For example: red- back light, blue- neutral light.... etc (<------examples of course, not real color match)
Get it? if you do please let me know where a diagram i asap! im emailing a guy that will help me if i give him the diagram.
The diagram of the speedo is on the pdf, if you have something similar to that for the ninja please post it!
thanks
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old November 5th, 2012, 09:42 PM   #2
skilletmo
InfoWhore
skilletmo's Avatar
Here they are sorry
File Type: jpg $T2eC16d,!ysE9sy0jKf0BQd97m6YSQ~~60_3.JPG (145.1 KB, 23 views)
Old November 6th, 2012, 08:57 AM   #3
HKr1
IC2(SW)
HKr1's Avatar
It's all on the schematic.
http://www.ninjette.org/forums/showthread.php?t=35886
Old November 6th, 2012, 11:47 AM   #4
skilletmo
InfoWhore
skilletmo's Avatar
can any one match the colors with the function that is is used for? im so lost on that diagram.
I need to know:
Oil: Blue/red (my Speedo had everything but the oil pressure... So that was empty on my connector)
High beam:red/black (in other 3 pin connector with the right turn signal)
N:light green
Speed: On cable for front wheel
water temp:red/yellow
fuel:light green/black
left turn:green
right turn:grey(on different connector with the High beam (3pin) )
back light multiple colors but in my case i didn't need that because mine ran on one led circuit.
power -:AKA ground wire black/yellow
power+:brown or red/blue (you can use either one) In my case i only needed one power + not many becuase mine was led and didnt need all those back light wires my original speedo had. Just one led light altogether on one wire.
rpm:black
spare power(power that is always connected to battery): You need to make your own, its very simple. Grab a wire long enough to go from your speedo to your battery and on one side put a connector for the harness and another a connector for the battery.
whatever you can find out of these is fine!
Edited the things i know for people in the future having a hard time with universal gauges, i know you love me.
Last futzed with by skilletmo; December 21st, 2012 at 02:13 PM.
Old November 6th, 2012, 12:26 PM   #5
skilletmo
InfoWhore
skilletmo's Avatar
is power -: black?
power +:brown?
Old November 6th, 2012, 11:58 PM   #6
skilletmo
InfoWhore
skilletmo's Avatar
Ok with a million hours of research and **** i found out where all the wires go, i just have one problemoooo. Does anyone know which wire is the one that stays on the power whenever the bike is turned off, i asked the guy i bought it from and the purple wire on my gauge is labeled "spare power" and i he said that "The purple cable should connect to the spare power, that means when you turn off the motorbike key, it is still connect with power." Does any one know what wire that is, and its not ground! Because i already have a ground and a positive in there which are the black and yellow and brown or red/blue. If any one knows please post it!
thanks
Old November 7th, 2012, 10:36 AM   #7
EMSRacer07
EMSRacer07's Avatar
thanks
on the pregen there are some lines that are "hot" when bike is off. Not sure about the newgens. But might be one next to the horn. Or better might be just wiring it straight to the battery.
Old November 7th, 2012, 10:43 AM   #8
1988+ Ninja EX250 FULL Wiring Diagram here! jonthechron 1986 - 2007 Ninja 250R Tech Talk 20 May 20th, 2023 08:53 AM
2008+ Ninja 250r FULL Wiring Diagram here! jonthechron 2008 - 2012 Ninja 250R Tech Talk 40 August 15th, 2022 09:11 AM
Wiring diagram and Repair Manual EMSRacer07 2013 - 2017 Ninja 300 Tech Talk 2 October 27th, 2013 04:27 PM
Wiring diagram bruce71198 1986 - 2007 Ninja 250R Tech Talk 4 September 20th, 2013 05:22 AM
300 Wiring Diagram Foxrider64 2013 - 2017 Ninja 300 Tech Talk 2 June 3rd, 2013 12:24 PM
