June 4th, 2024, 10:55 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): Blue 2009 Ninja 250R Posts: 26
Gas came out during oil change
Hi everyone,
My bike has been sitting unused for a few years. I tried starting it and no luck so I took the carb out to clean it. Turns out it wasn't dirty at all. Put it back and it still wouldn't start. Decided to give the spark plugs a try and the bike started right up but after a few minutes gas started pouring out from the carb. After much weeping I went through the hell of removing the carb again. Turns out the diaphragm for the needles got torn somehow when I first serviced it. Replaced the diaphragms and put the carb back in. Started right up and sounded like it was running great. I went to change the oil next and when I opened the drain plug a ton of gas came pouring out. Was this gas from when it was first overflowing the carb? I also noticed I had left the petcock on prime when I started it up. Did leaving the petcock open cause all the gas to dump into my engine? I refilled it with oil and plan to drain the oil again before doing the oil change. Will that be sufficient or did I screw up my bike elsewhere and I have bigger problems? Thanks for any info you can provide. |
June 5th, 2024, 05:22 AM | #2 |
Join Date: Jun 2013 Motorcycle(s): 2005 EX250, 1975 Suzuki T500, 2018 Kawasaki Z900RS Posts: 31
My assumption would be that the oil got diluted when the carbs were overflowing.
I'd run it for the same length of time as before, and check the oil level. If it hasn't changed, you're good, but if it's high and full of gas again, I guess there's something else to fix. It's possible there's something up with the petcock, but I wouldn't expect it, if the carburetors were obviously malfunctioning. When working normally, it shouldn't do anything that would cause trouble. I think your bike is fine. You don't want to run a bunch of miles with a high oil level, or with bad fuel dilution in the oil, but if it's not already making a new noise it's probably good to go. |
June 5th, 2024, 05:25 AM | #3 |
Leaving the petcock on "prime", in combination with leaking float valves, is most likely what got gasoline into the oil. If you have corrected the float valve leakage, and if the petcock works properly, you're probably in the clear in that regard.
(Typed in parallel with ACL 9000's post above) |
June 5th, 2024, 09:30 PM | #4 |
Thanks for the reassurance.
I ran the engine and it doesn't appear to have gas filling up in the oil window so I think I'm going to be ok. |
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
Synthetic oil at 300 mile oil change? | anacron | 2013 - 2017 Ninja 300 Tech Talk | 14 | July 29th, 2013 04:58 PM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
