Old October 8th, 2013, 08:44 PM   #1
caineroad
caineroad's Avatar
Motorcycle(s): 2010 Ninja SE
How to reset the odometer?
I replaced my speedo cluster with another one because the fuel gauge no longer worked but the mileage on the new one is double the mileage of the original one, how do I set back to lower mileage? thanks
caineroad is offline   Reply With Quote
Old October 8th, 2013, 09:36 PM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Pretty sure tampering with an odometer is illegal... I think in these cases it's just something to be noted for records.
Old October 8th, 2013, 09:46 PM   #3
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Yep, rolling back the odometer is illegal.
Though the fuel gauge is separate from the speedo/odometer, is there a way to just install the fuel one? I've seen them for sale individually on ebay.
<-- Linky
Old October 8th, 2013, 09:48 PM   #4
caineroad
caineroad's Avatar
Oh... didn't know I could replace the fuel gauge alone. Anyway I sold the original one already and replaced with the used one, is there a way I can roll back the mileage? I don't really care up here in Canada, I am gonna keep the bike for myself anyway
Old October 8th, 2013, 09:49 PM   #5
Joshorilla
Bass Master General
Joshorilla's Avatar
Some criminally minded people would detach the cable from the wheel and use a drill attached to the cable to spin it backwards and roll back the clock.
But I do not suggest you do this.
Old October 8th, 2013, 09:51 PM   #6
tfkrocks
tfkrocks's Avatar
If you're just keeping if for yourself, why worry about it? Just write down the original mileage when you changed it out and what the current odometer started at. Should be all you need whether you're keeping track of maintenance or selling the bike down the road anyway.
Old October 9th, 2013, 07:49 AM   #7
They don't spin backwards. Just roll the front wheel backwards to confirm. You'd need to run the drill quite awhile to roll the odo over and back to 0.
Old October 9th, 2013, 08:19 AM   #8
LNasty
Daily Jap rider
LNasty's Avatar
haven't you ever watched Ferris Beullers? one minute you have a priceless Ferrarri on jacks, next it's 100 ft over the ledge and smashed like a pancake....just leave it alone, your dad will understand.
Old October 9th, 2013, 08:32 AM   #9
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
You should be able to get in there and manually reset the individual numbers. Never tried on the Ninja but the odometer is no different than most.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old October 9th, 2013, 09:41 AM   #10
Joshorilla
Bass Master General
Joshorilla's Avatar
That's a bit of a shame, the older mechanical odo's you used to be able to wind backwards as they're just a gear train with an incredibly small reduction ratio, set them on a bench with a drill and leave for x number of days / weeks.
Old October 9th, 2013, 09:49 AM   #11
caineroad
caineroad's Avatar
Sounds a lot of work, does it work?
Old October 9th, 2013, 09:59 AM   #12
red5
red5's Avatar
Mmmmmm don't know. If you can get inside the gauge cluster it will.
Old October 9th, 2013, 11:13 AM   #13
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
get really aquainted with the assembly and grab a very good new set of needle nose plyers and pull the pin hodling the wheels. I saw it done in the mecedes dealer when replacing the odometer witha factory replacemetn one, so it reflects current mileage. Nothing wrong with doing it imo. Of course pulling the pin may cause your odo to grenade itself.
My Cafe Racer Build
My intro post
Old October 9th, 2013, 12:25 PM   #14
Compooky
Motorcycle(s): 2011 ninja 250r, 2013 gsxr 600
+1 just leave it alone since there's no reason to change the odo numbers. A benefit to this is you can claim more riding experience than you actually have.
And if you do change the odo and decide to sell it down the road later on, the likely scenarios are
1. You inform the buyer but have no receipt from a dealer or the original odo to prove mileage which makes it suspicious.
2. Just be an ass and don't tell any one.
Compooky is offline   Reply With Quote
Old October 9th, 2013, 12:41 PM   #15
Boom King
So, where's the reverse?
Boom King's Avatar
I would've just kept the original cluster to be honest if the only thing that wasn't working was the fuel gauge. Even when it works, it doesn't work. It's about as accurate as trying to piss on a bullseye against the wind. Just fill up before 300 kms and you'll be fine.
Old October 9th, 2013, 06:19 PM   #16
Runeknight95
Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only
This lmfao
Runeknight95 is offline   Reply With Quote
Old October 9th, 2013, 06:23 PM   #17
Panda
not an actual panda
You need to Ferris Bueller it.
Old October 9th, 2013, 06:59 PM   #18
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Don't hook up the cable.
Ride for the same amount of time you owned the bike before you swapped. Chances are you follow a pattern in your riding, so the mileage over time will be close.
Then hook it up. The mileage should be close enough.
You don't really care about the speed, right? Just ride at the pace of traffic.
Old October 9th, 2013, 07:38 PM   #19
caineroad
caineroad's Avatar
But how do you get the speedo without plugging the cable? It would be nice to know my speed so I am not speeding right lol
Old October 9th, 2013, 07:40 PM   #20
tfkrocks
tfkrocks's Avatar
You don't. That's why he said go the speed of traffic.
Old October 9th, 2013, 07:41 PM   #21
caineroad
caineroad's Avatar
That sounds like a plan! Which cable is it from the cluster?
Old October 9th, 2013, 08:15 PM   #22
tfkrocks
tfkrocks's Avatar
The one that goes down to the front wheel.
Old April 30th, 2014, 05:52 PM   #23
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
A little info on this I just attempted to do this with the parts bike odometer and every single wheel is locked in tight and it's made out of stronger metal then the frame of the bike.
Old April 30th, 2014, 06:14 PM   #24
it's quite a bitch. intentionally. just put some black tape over the number and say "lalalalala"
Old April 30th, 2014, 06:29 PM   #25
fishdip
fishdip's Avatar
And lets have a visual aid or 2
Old April 30th, 2014, 06:31 PM   #26
fishdip
fishdip's Avatar
I am doing it right... I got out the black paint and brush.
Old April 30th, 2014, 06:32 PM   #27
i like your idea. you have so many font options when painting the numbers back on
Old May 2nd, 2014, 08:11 AM   #28
SpidermanGeek
SpidermanGeek's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r SE
... is there a way I can roll back the mileage? I don't really care up here in Canada, ...
Uh yeah, Odometer tampering is Illegal here too, lol.
http://www.rcmp-grc.gc.ca/qc/service...ection-eng.htm
SpidermanGeek is offline   Reply With Quote
Old May 6th, 2014, 07:03 AM   #29
kennetht
kennetht's Avatar
just undo the speedo hose from the wheel end, and pull out the cable from the rubber hose. then reattach the hose to the wheel end, with the cable wire left out. ride for a while until you think the miles will match, and then reinstall the cable, and your done. easy.
kennetht is offline   Reply With Quote
Old May 6th, 2014, 08:05 AM   #30
Redgeneral
Redgeneral's Avatar
Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650
I know there are specificaly licensed shops that can set your new odometer to the same number as your old one legally. But I'm almost positive you require your old Odometer.
Though you do have to give your mileage when you get your plate sticker. You could always give your local dealer a call if they know a reputable shop that can adjust it legally.
Otherwise, the black electrical tape method is your best bet.
Redgeneral is offline   Reply With Quote
Old May 6th, 2014, 08:24 AM   #31
sonny4472
sonny4472's Avatar
Motorcycle(s): 09 250r, 09 1125r, 95 Virago
This thread may have some of the worst advice I've ever seen!
Just ride the bike backwards for a few thousand miles.
sonny4472 is offline   Reply With Quote
Old May 6th, 2014, 08:45 AM   #32
250rr
250rr's Avatar
Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty
Paint a cherry with a little stem and green leaf on each zero. Then, every 1ooo miles you win the lottery.
250rr is offline   Reply With Quote
Old May 6th, 2014, 09:13 AM   #33
kennetht
kennetht's Avatar
best answer yet
[motorcyclenews.com - sport] - Nicky Hayden: Marquez ‘reset the bar’ in 2013 Ninjette Newsbot Motorcycling News 0 December 5th, 2013 04:02 AM
[motorcyclenews.com - sport] - Nicky Hayden: Marquez ‘reset the bar’ in 2013 Ninjette Newsbot Motorcycling News 0 November 18th, 2013 04:32 AM
[motorcyclenews.com - sport] - Nicky Hayden: Marquez ‘reset the bar’ in 2013 Ninjette Newsbot Motorcycling News 0 November 18th, 2013 03:01 AM
[superbikeplanet.com] - Reset: Nick's New Lid Ninjette Newsbot Motorcycling News 0 November 5th, 2013 03:00 PM
Trip Odometer Reset Problem Scattcatt 2008 - 2012 Ninja 250R Tech Talk 5 January 31st, 2012 09:42 AM
