September 28th, 2019, 11:14 AM | #1 |
Join Date: Sep 2019 Motorcycle(s): 2008 Ninja 250 Posts: 17
Suggestions please
I just reinstalled the carbs ( just connected to the head side to see if the were put back together properly ) before i reassembled everything. I got the bike to run. However after letting it sit for about an hour I tried to start it one more time before putting it all back together..... can't get it to fire up
Any help would be greatly appreciated |
September 28th, 2019, 02:08 PM | #2 |
Measure vacuum at petcock when cranking. Loose-fitting or cracked vacuum hose can open up more when warmed up. Causing loss of vacuum on way from carbs.
Verify petcock doesn't leak petrol when off. Should only flow when vacuum applied. Verify float-valves in carbs stops petrol flow at proper height. Test for spark at spark-plug wires. |
September 28th, 2019, 05:21 PM | #3 |
Carbs. :/
Soo - I got the bike to start if I spray starting fluid into them.
I pulled the carbs out and Iam going to go thrunthem again just in case something got into them from the fuel line (since I didn't have a fuel filter in) Is there anyway to test if the bike will run without putting the gas tank back on? Can I just put the fuel hose into a small gas can ? Also, is there a right way and a wrong way for the little needle to hang on the float bowl? Thanks again for any advice |
September 28th, 2019, 07:53 PM | #4 |
Yup, you can fill small bottle with petrol and hang it above carb with hose. Kinda like an IV-drip for bike!
Don't use starting-fluid as it will melt sensitive components of carb and make things worse. Depending upon how long bike has been sitting, very likely it's clogged with dried petrol plastic varnish. This requires complete disassembly to last nut, bolt and individual component. Rubber o-rings and seals replaced. All jet-holes, bleed-holes and fuel-circuits physically scrubbed and flossed with wire. Ultrasonic dip with radioactive caustic solvents for months on end. Micro soda-blasting @ 100000psi to clear everything out. Do search for "clean carbs ducatiman" for more photos and details. Basically you want to restore carbs back to factory-fresh condition like it was when leaving showroom floor. Anything less will result in compromised functionality. |
September 29th, 2019, 01:53 AM | #5 |
/moved to new-gen tech
September 29th, 2019, 06:05 AM | #6 | |
Needles simply slide on to float tang...into seat and float pins contain the works. If you continue to have issues requiring frustrating, repeated carbs on/off sessions...I'm at your service for a true, pro resto....way beyond clean. PM if you are so inclined. PS ditch the start fluid....plastic slides and diaphragms are allergic to that stuff!
Custom Carb Service |
September 30th, 2019, 06:46 AM | #7 |
Thank you!
Thanks for the feedback. I had no idea starter fluid was so bad when used sparingly. Also, are there any link she that show how to properly adjust the floats? I have a digital caliper that I bought to do it. When I look at the both sitting in the bowl. They appear to be at different heights, just by looking at them. Also - is there a right way to hang the little needle on the float? It appears that the little wire you hang is off set a little
Thx again for all help. |
October 1st, 2019, 06:47 PM | #8 |
Thanks for the input.
Hey all. Thanks again for your help and suggestions. I went ahead and replaced the 2 pilot jets and made some float adjustments and the bike is now running.
Iam going to do an oil change next and possibly make some clutch adjustments. The shifter is very hard to kick up... I'm not sure what the cause might be. Have a good night! |
October 1st, 2019, 08:50 PM | #9 |
Could be clutch.
Could also be shift linkage. Two short arms connecting each end of shifter-rod should be as close to 90-degrees as possible to rod. This ensures maximum rotation of gear-change shaft when you move shift-lever. If either lever is too far away from 90-degrees, moving shift-lever just tries to stretch shift-rod in one direction or other rather than rotate gear-change shaft. |
Kickstand Suggestions | LilMiss | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 24th, 2014 10:03 PM |
Tires! I need suggestions. please | hpav13 | 2008 - 2012 Ninja 250R Tech Talk | 4 | December 16th, 2013 08:38 PM |
Need some suggestions with this situation | bikermunda | 2008 - 2012 Ninja 250R Tech Talk | 13 | September 14th, 2010 06:53 AM |
Boot suggestions? | jeffwessel | Motorcycle Gear | 9 | March 25th, 2009 09:57 AM |
