September 6th, 2020, 05:07 PM | #1 |
2006 ninja 250 fuel problem
So i have a jet kit installed i have 42 pilots 112 mains and 2 shims and the fuel mixture screws at 2 3/4 turns out it running fine infact im going to go to 118 mains but the problem im having is when i go to ride and get on it for a minute and im burning gas faster then the carbs can fill up no vacuum leak it will shut off on me and i have to prime the carbs again and it starts right up no problem and will do it again anyone else have this problem the float level is stock i have 40 hp
September 6th, 2020, 05:50 PM | #2 |
What mods to do have to get this 40hp? Any dyno-charts with AFR?
How are you priming carbs? Many causes of low gas flow. 1. Insufficient vacuum to petcock. Do you have vacuum-gauge and can measure actual vacuum-level that goes into petcock? I had issue on my race-bike with vacuum line getting coiled up and pinched under tank. Made it about 1.5-laps and engine would die. Let sit for couple minutes on PRI and it’d start right up. Got back to pits, pulled tank off to take look. Everything’s fine, ran for 10-minutes no problem. Bolted everything together and went out again. Exactly 1.5 laps in, fizzed to stop again! Sat for while, started right back up. This time, i connected rubber-T to petcock and measured vacuum. Bolted everything back up like I was going out on track. Even sat on bike. Watched vacuum-gauge and sure enough, after initial amount to open petcock, vacuum went down and down until petcock shut off and my carbs ran dry! Looked carefully at vacuum hose and there was certain curve that became sharp kink and cut off vacuum when I bolted down tank. 2. Low flow from petcock. Disconnect fuel-line from carbs and aim into measuring cup. Using vacuum-pump, apply exact amount of vacuum you measured going to petcock in step#1 to petcock’s vacuum line. Time flow for 30s (use stopwatch). How much petrol did you collect in 30-seconds? Last futzed with by DannoXYZ; September 6th, 2020 at 07:23 PM. |
September 7th, 2020, 05:12 AM | #3 |
I took it back out last night after i changed the fuel line to 5/8 and took off the inline filter that was on it it ran better got it to run longer but not right no vacuum leak it does the same thing on prime im going to raise the fuel level and see if that helps
September 7th, 2020, 11:53 AM | #4 |
Does yours still have the tiny filter that's right at the carb inlet, that's hidden until you take off the fuel line?
September 7th, 2020, 11:57 AM | #5 |
If that little filter gets installed backwards, it will crumple into a wad and block flow. Best to replace with in-line filter to make it easier to inspect.
Still, without any concrete measured numbers, hard to diagnose anything. |
September 7th, 2020, 02:40 PM | #6 |
Yeah, even in it's installed correctly it'll get clogged, and if you don't know it's there you scratch your head and try to figure out why nothing you do cures the fuel flow problems. Like I did that is.
September 7th, 2020, 05:21 PM | #7 |
call me curious. I'd like to know what engine configuration demands such extreme jetting and flow characteristics?
September 8th, 2020, 04:51 AM | #8 |
Ya it has the filter its lookes new also i had an inline filter but i took it out and installed 5/8 im going to try to get a high flow peacock on it and see if that works.running 42 pilots and 112 mains 2 shims and 2 3/4 turns out its still not running rich going to go with 118 mains and see how it runs. Exhaust manifold from a 454 ltd modified duel to the stock mufflers and Head work the previos owner said he bored it over havnt had to tear it down yet to see what pistons it has on the 06 and waiting on parts for the 05 just did the head on that one and picking up a 85 900 Wednesday
September 8th, 2020, 06:13 AM | #9 | |
I can't imagine it would be running lean with those jets, and unless it was a total monster engine I would think it's way rich all over. Have you looked at the plugs? I would expect them to be black. I wouldn't use the float level to adjust the mixture. |
September 8th, 2020, 10:24 AM | #10 | |
Join Date: Oct 2019 Motorcycle(s): Ninja ZZR250 (EX250H) Posts: 213
Or the new filter might not have enough flow capacity. |
September 8th, 2020, 11:01 AM | #11 |
have you determined presence of fuel and level in bowls using the clear tube method?
September 8th, 2020, 07:58 PM | #12 |
Just changes the plugs they werent black or grey though the electrods where worn and im going to check the fuel level again the floats are set at 17mm
September 8th, 2020, 08:43 PM | #13 |
Well, 17mm would be float-level IF flow-rate from petcock can keep up. No one knows exactly how much petcock is actually flowing.
September 12th, 2020, 02:38 AM | #14 |
Here’s how to test and measure petcock. Engineers didn’t come with this just for fun. The numbers make a difference and pinpoints what’s wrong. And tells you exactly how to fix it.
Last futzed with by DannoXYZ; September 12th, 2020 at 08:30 AM. |
Draining fuel on lower Carburetors ? Ninja 250 2006 | moviepilot | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 2nd, 2019 05:34 PM |
06 ninja 250: FUEL PROBLEM- starts with starting fluid then dies | Jduncan_13 | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 3rd, 2019 05:51 AM |
