Old November 23rd, 2019, 06:45 PM   #1
theratbiker
Motorcycle(s): EX250, KLR685, LS650, NT650
Looking for handlebar risers for a 2007
I'm looking to buy handlebar risers for my 2007 ex250. Like these:
http://www.powersportsfx.com/sa/cart...33F619FB382%7D
Though they seem to be out of business. Anyone know another source or got a pair to sell?
Thanks!!!
theratbiker is offline   Reply With Quote
Old November 24th, 2019, 09:20 AM   #2
Greetings & Salutations and welcome to Ninjette Lester!
Your best bet for taller position is to get generic bar clamps that bolt to centre of upper triple-clamp. Then you can select from huge variety of one-piece bars.
https://www.ninjette.org/forums/show...17957&p=768498
Old November 27th, 2019, 02:43 PM   #3
theratbiker
Appreciate the information, but specifically looking for the risers for the stock handlebars. Thanks.
Old November 29th, 2019, 07:50 AM   #4
Back in the day we used Ninja 250 bars on our race Ninja 500 because they were lower. The inside needed to be opened-up because the 500's tubes were larger, but other than that they bolted on.
So if you used a set of EX/Ninja 500 bars they would be higher, but you may want to come up with some type of shim to get a snug fit on the smaller 250 fork tubes.
Old February 13th, 2020, 04:19 PM   #5
Found set for '08-12 new-gen. Not sure if they'll work on earlier models.
https://www.aliexpress.com/item/4000670035379.html
EDIT: This will work on pre-gen 250s to raise bars. But you have to shim ID to fit smaller 36mm forks. And drill 2 new holes to fit narrower spacing on pre-gen bars.
Last futzed with by DannoXYZ; February 14th, 2020 at 04:57 PM.
Old February 13th, 2020, 09:36 PM   #6
Artruck
Motorcycle(s): 2007 ex250 (black), silver 2005 ex250 scrambler, 2003 ex250 donor bike, 2006 kymco people 250
Wouldn’t the bars still be 7/8ths on both? So couldn’t you just swap all the controls from the 250 bars to the 500 bars and just bolt them to the forks?
Also one guy online used to make risers for the 250, the website is still up and you can place an order and send money, but the parts never show up and there is no response from the site. They are expensive at 100 bucks for aluminum blocks to adjust bar height.
Artruck is offline   Reply With Quote
Old February 13th, 2020, 09:50 PM   #7
He's talking about the riser part of the bars. They bolt to upper triple-clamp and cover top of fork tubes. Ex500 has 37mm tubes while pre-gen has 36mm tubes. To fit the shorter/lower risers from 250 onto EX500 requires boring out big hole in bottom from 36 to 37mm so they fit over EX500's larger fork tubes. To prevent loading bolts in shear (engineering no-no), you want them to fit snuggly over fork tubes.
Last futzed with by DannoXYZ; February 15th, 2020 at 08:30 AM.
Old February 13th, 2020, 09:53 PM   #8
Artruck
Of course, totally missed that.
Handlebar risers Brian250R 2008 - 2012 Ninja 250R Tech Talk 29 January 11th, 2016 02:31 PM
Short handlebar risers/spacer Hybridchemistry 1986 - 2007 Ninja 250R Tech Talk 5 October 19th, 2015 03:25 PM
My version of handlebar risers KChatham 1986 - 2007 Ninja 250R Tech Talk 19 October 4th, 2012 03:46 PM
SHINTO Angled Handlebar Risers ThaiNinjaRR Motorcycle-related 44 October 8th, 2010 05:12 PM
Any benefit to handlebar risers only??? Lil_ninja 2008 - 2012 Ninja 250R Tech Talk 11 April 25th, 2010 02:44 PM
