Go Back   ninjette.org > General > Pictures
Old July 25th, 2012, 09:15 AM   #1
dbking321
dbking321's Avatar
Motorcycle(s): 09 ninja 250,93 vulcan 750
Post your Pre Gens
I dont know if this has been done before but everyone post your pregens with a list of what you have done to them.
First is the silver 05 ninja i bought for my fiance. got it with 15000 on it and it has never been down and is in awsome shape. its been lowered with flushmount signals fender elimination and gearing change. Picked it up for a steal.
Second is my 07 ninja got it with 4000 miles had been wrecked but i fixed it pretty well. It was wrecked on the side the pic is of. it has flush mounts fender elimination and twobrothers exhaust. getting a 15t shortly.Also got it cheap
dbking321 is offline   Reply With Quote
Old July 25th, 2012, 09:22 AM   #2
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
2003 Ninja 250. 6K miles. I've brought it down in my alley after hitting some sand.
- Added extra brake lights in the empty pods in the tail.
- Changed the bar ends
- Installed a Freeway Blaster horn
I have more to do. I have all the parts to convert the front reflectors into running lights, and to change the turn signal connectors to molex connectors. I also plan to paint her this winter.
iplante is offline   Reply With Quote
Old July 25th, 2012, 09:22 AM   #3
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
Both beautiful bikes! I'll take a pic on my next break and post it!
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old July 25th, 2012, 09:51 AM   #4
Check my sig for everything I've done to my bike! There's a little too much to list
The only things that aren't listed correctly are my fuel injection conversion and k&n pod filter
I'll try and post up a good picture next time I'm on an actual computer.
Posted via Mobile Device
Old July 25th, 2012, 10:10 AM   #5
dbking321
dbking321's Avatar
nice bike it looks like it was well kept
Old July 25th, 2012, 10:18 AM   #6
iplante
iplante's Avatar
Pointing the obvious... you don't have a sig.
Old July 25th, 2012, 10:32 AM   #7
Check his mods out:
http://www.ninjette.org/forums/blog.php?b=231
This is mine, fully stock 2007, which is more than good enough for me.
Old July 25th, 2012, 12:04 PM   #8
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Agh my eyes!
AFM #676
Supersports are for n00bs
Old July 25th, 2012, 03:50 PM   #9
Stingray1000
Pic
Old July 25th, 2012, 03:59 PM   #10
OK, no more stock fenders. I've had more than I can take! Think of the kittens.
Old July 25th, 2012, 04:03 PM   #11
Stingray1000
I think cause he was using the mobile version it doesn't show his sig? Could be wrong.
Old July 25th, 2012, 04:18 PM   #12
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
OK here's mine, an '04 with ~15k miles.
Mods include: BT-45s, '08 J-model rear shock, GS500f fork springs, 15wt fork oil, rear fender chopped, LED brake lights in extra pods, smoked pod lenses, custom flushmount front signals, 15t front 42t rear JT sprockets, Pro-grip grips and tankpad, Mike's sport shield for cold weather/ touring.
Whew, I think that's everything.
Old July 25th, 2012, 06:59 PM   #13
dbking321
dbking321's Avatar
how do you like the suspension in your bike. I have been thinking about stiffing mine up
Old July 26th, 2012, 05:24 AM   #14
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
It's not bad. The shock from an '08 250 was a nice upgrade for the 50$ I paid for it. It raised up the rear a little, and makes riding 2 up much better. It's also better when the pace picks up in the twisties. I haven't messed with adjusting the preload, I weigh 145lbs and it's been on the first setting since I installed it.
The front forks are a bit too stiff, even though the springs are still softer than recommended for my weight. I definitely don't worry about front end dive anymore. I will probably go back to the stocks springs at some point, but keep the heavier 15wt oil.
If you can find a good deal on a shock go for it. I like the J-model shock because it's made for a bike of similar weight and power, but plenty of people go for ones from other bikes. Then pick up a bottle of fork oil and you'll be good to go.
BTW with 90 series tires and the new shock I have to put a 2x4 under the centerstand to get the rear tire off the ground.
Old July 26th, 2012, 06:09 AM   #15
93etgocart
93etgocart's Avatar
Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250
what a chance to pic whore my bike of course ill share... its a 2000 with a little over 10k and climbing everyday. Only real mods are flushmount front turn signals and under lighting.
93etgocart is offline   Reply With Quote
Old July 26th, 2012, 06:28 AM   #16
It also looks like a different shade of solid green
Old July 26th, 2012, 08:16 AM   #17
iplante
iplante's Avatar
RE: stock fender
i'm thinking of buying another one cheap on the 'bay so I can cut it and modify it but still keep the stock fender just in case.
The thing is i want to keep my turn signals in the back, i don't want to integrate them into the tail light. Plus, I don't want to spend more than 30 bucks on the whole thing :P
Old July 26th, 2012, 08:41 AM   #18
How much would it cost to ship? I still have my stock fender I'm happy to part with for 30 shipped, I'll just have to get a box for it and ship it. But I won't do it if shipping is like $25 or more
How much are the eBay sellers asking for shipping on a stock fender?
Oh PS the only thing not stock about my oem fender is i cut the wires to the plate light. Bit that shouldn't matter for you if you're going to hack it up
Old July 26th, 2012, 07:34 PM   #19
dbking321
dbking321's Avatar
common guys post some pics
Old July 26th, 2012, 09:04 PM   #20
Jono
Jono's Avatar
My pregen. Kinda a old pic. It is still a work in progress but I am going for a modern day cafe racer look. Future upgrades... clipons, possibly K&N pod airfilters, different taillight. The list goes on and on. Haha. I am currently in the process of painting the gas tank. Just failed at using bondo for the first time on the gas tank this evening . I have to sand it all off and try again this weekend.
You can follow my work here... http://www.ninjette.org/forums/showthread.php?t=100916
Old July 26th, 2012, 10:23 PM   #21
Jiggles
Jiggles's Avatar
MOTM - Apr '13
^ ****er jacked my bike!
AFM #676
Old July 26th, 2012, 10:37 PM   #22
Jono
Jono's Avatar
@Jiggles Naw mine isn't deathproof. Haha. How did that whole project turn out for you.
Old July 26th, 2012, 10:38 PM   #23
Jiggles
Jiggles's Avatar
MOTM - Apr '13
You know what's funny, I now have the money to complete that project, but I sold it to my dad so we could ride together, lol oh well
AFM #676
Old July 26th, 2012, 10:42 PM   #24
Jono
Jono's Avatar
Buy it back from your pops.
Old July 26th, 2012, 10:55 PM   #25
EMSRacer07
EMSRacer07's Avatar
Here is my guy after my vinyl job i did myself. and mods in my sig
my wheels are next to be white or black. havent decided hope you enjoy the vinyl job took a while and was very hard to get all the curves and do the two tone. its the CF vinyl. Props go to Metro Restyling for good quality stuff comparable or better than 3m and really good prices.
Old July 27th, 2012, 04:41 AM   #26
dude what happened to your can?? I don't remember it being funny colors like that. I remember the tip being turned in, but not the colors.
Edit: I'll get some new pics of my green lady this weekend. Maybe tonight even. She got washed and waxed last weekend, but then got dirty on Tuesday. Oh well. Always happy to show off a little
Old July 27th, 2012, 07:11 AM   #27
Lychee
sail away
Lychee's Avatar
Originally Posted by EMSRacer07 View Post
double-bubble
Dayam, I thought ninjamunky's windshield was awesome but this one is even better. How much did it set you back?
Old July 27th, 2012, 07:30 AM   #28
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
I looked at the double bubble before I bought my windscreen, but mine is taller and wider than the double bubble, and cost a lot less. It doesn't matter though, since you can't get Mike's Shields anymore. Too bad ,cause they were awesome.
http://www.mikesshields.com/
P.S I do plan on painting it though, but I still use the stock shield most of the time.
Old July 27th, 2012, 10:43 AM   #29
EMSRacer07
EMSRacer07's Avatar
its titanium so it got worse as it got too hot lol.
Old July 27th, 2012, 10:43 AM   #30
EMSRacer07
EMSRacer07's Avatar
65 bucks from zero gravity ebay store.
Old July 29th, 2012, 08:33 AM   #31
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
My 2000. Bought it with 2845 miles. Just turned it over 6k miles. So far all I've got done to it is I changed over to GP shifting. I've got EX500 levers and clutch perch waiting to go on and Pirelli rubber and Vesrah front brake pads coming in the mail. Hopefully by next season it will be all boy-racer'd out. I've got a very good idea of what I want to do to my bike now.
dirty nasty is offline   Reply With Quote
Old July 29th, 2012, 01:49 PM   #32
highpsiguy
highpsiguy's Avatar
Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250
2002 Ninja 250-
"Rudeness is a weak persons attempt at strength."
highpsiguy is offline   Reply With Quote
Old July 29th, 2012, 07:46 PM   #33
Its going to look identical to mine! Racer boy'd out...
Old July 30th, 2012, 09:28 AM   #34
Bosgarage57
Bosgarage57's Avatar
Motorcycle(s): 06 Buell Uly, 05 VStar 1100
Here it is before the conversion
And as it sits now:
Bosgarage57 is offline   Reply With Quote
Old July 30th, 2012, 09:48 AM   #35
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
I suddenly want a pre gen now too. The heck!
walty87 is offline   Reply With Quote
Old July 30th, 2012, 09:49 AM   #36
BlackNinja8
BlackNinja8's Avatar
Motorcycle(s): 2011 250R (Sold); 2012 Vulcan 900; 2009 Harley Iron 883; 2004 SV650s; and a bunch of others over the years...
Thanks a lot guys now I want a naked pre-gen...
BlackNinja8 is offline   Reply With Quote
Old July 30th, 2012, 10:38 AM   #37
Lychee
sail away
Lychee's Avatar
Bought one for myself! Thanks!
RIP Mike's Shields
Old July 30th, 2012, 11:12 AM   #38
Stingray1000
Love this!
Old August 9th, 2012, 02:50 PM   #39
Finally putting up some pictures!!
She's a '99, just turned 17k, and other than putting me through some stress with a little head work this season, she's the best!!!! LOVE HER BUNCHES!!
trippy headlight pic:
getting ready for the track:
artsy:
reppin ninjette.org yo!
so clean!
showing off my fuel injection parts
aaaand, gotta get my mtb in here, @akima might like this one. and @Kevin2109, this is Mik's little sister, kinda like Gizmo and your single speed
This is a good shot of the valley with Mik
here we are at the track. I have a couple pictures from the professional photographer there, but my flashdrive is being dumb right now
alright, that's all my picwhoring for now. Hope you all like my pregen sorry about the wait for those pictures. I've been damn busy lately with 2 jobs
Old August 9th, 2012, 03:40 PM   #40
Monkeytofu
I told you bro
Monkeytofu's Avatar
Didn't know we had a pregen thread in the picture section. Here's mine from a month or two ago before I repainted my exhaust system:
Family got a brand new Nikon DSLR so once my bike is up an running I can get some nice shots of the bike with some repainted parts :O
Pre-Gens on the Dragon! livewire83 Videos 2 April 19th, 2014 11:16 AM
Exhaust systems for pre-gens psych0hans Motorcycle-related 5 March 8th, 2014 02:16 AM
custom pre gens darrell85 General Motorcycling Discussion 2 September 1st, 2010 11:18 AM
16 teeth front sprocket - fits pre-gens and new-gens Rayme Motorcycle-related 2 August 2nd, 2009 10:18 AM
New Rearsets for Selected Pre-Gens: komohana 1986 - 2007 Ninja 250R Farkles 31 June 2nd, 2009 12:44 PM
