Old March 29th, 2014, 11:08 PM   #1
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
Rear sprocket bent chain adjuster
Working on the bike the past few days and noticed that my chain adjuster was bent 35 or so degrees outward with the back plate hanging off with one nut barely on. Did not notice this happening while riding a week or so ago.
Upon closer inspection, the lock nut had fallen off. What had happened was it started to loosen, the plate came off and when it rotated must have got caught in the sprocket or hit by a sprocket nut and "BAM". No damage to the rear sprocket. Bent the adjuster back with a rubber mallet and now just have to get a new lock nut.
How I think it happened was when I was aligning the rear tire, I only hand tightened everything to get a near perfect alignment. After tightening the rear axle, I must have forgot to go back and tighten them better. The right side didn't do it, but that one seemed snugger.
Figured I'd post it to warn others to make sure those plates are tight after adjusting your rear tire and tightening the axle. This probably could have turned out worse during my ride, luckily it didn't.
linkinpark9812 is offline   Reply With Quote
Old March 29th, 2014, 11:10 PM   #2
its surprisingly common. i've never seen it turn out too bad. worst i've seen is lost hardware. locktite, silicone, or safetywire every bolt
Old March 30th, 2014, 08:52 PM   #3
Yup, pretty common. Here's another thread with the same issue:
http://www.ninjette.org/forums/showthread.php?t=34073
Chain adjuster came loose backinthesaddleagain 2008 - 2012 Ninja 250R Tech Talk 13 December 22nd, 2014 08:21 PM
Loose chain adjuster Slick_Stevo 2008 - 2012 Ninja 250R Tech Talk 4 July 8th, 2013 05:06 PM
How many links do I reduce my chain if adding 15t front sprocket, stock rear? novak2k9 2008 - 2012 Ninja 250R Tech Talk 2 February 11th, 2013 02:25 AM
Can I get away with a 104 link chain with stock gearing? If not, what rear sprocket? CZroe 2008 - 2012 Ninja 250R Tech Talk 5 June 16th, 2012 06:26 AM
[motorcyclistonline] - Gilles Precision Chain Adjuster Ninjette Newsbot Motorcycling News 0 March 30th, 2010 04:00 AM
