May 16th, 2013, 07:19 PM | #1 |
Join Date: Oct 2012 Motorcycle(s): 03 Ninja 250 Posts: 19
Mystery o-ring on oil screen?
Alright so I did my first oil change on a bike today and finally got to the oil screen. It didn't want to come out, but with a little encouragement from a mallet, it gave it a little wiggle and out dropped the screen as well as an unattached o-ring, about an inch in diameter
I tried to play around with it and see how it could have been seated on the oil screen, but it didn't seem like there was any way. It didn't want to stretch around it, and even if it did, there was no groove for it to stay seated on the screen. I checked the wiki and googled for similar problems but literally no results came back regarding an oil screen o-ring. I put everything back together while leaving the o-ring out. My bike doesn't leak oil, and it doesn't leak while running either. Do you think i'm alright? Has anyone had to deal with this o-ring before? The only info I could find was about the paper gasket on the oil screen cover. Also should I be worried about any of the oil change bolts vibrating loose while riding? I didn't have a torque wrench so I got them as snug as they were when I cracked em loose. I planned on riding for 10-15 mins then pulling over and checking them whenever I get out next. |
May 16th, 2013, 08:09 PM | #2 | |
As for as torquing the bolts. Snug is fine.
May 16th, 2013, 08:18 PM | #3 |
Nope I had the two oil filter o-rings taken care of, that's why this one surprised me. The mystery o-ring is a little bit bigger than the small oil filter o-ring, so maybe it's more like 1.5" in diameter
It was just completely random. I've never had any related issues with my bike though so i'm just going to try and pretend it never happened haha. Also, it's so nice seeing a nice gum-colored oil in the sight glass rather than the black oil that was in there since I bought the bike. I've heard a lot of people say the bike shifts much smoother after an oil change too so I can't wait to ride tomorrow and see what that's about. |
May 16th, 2013, 08:24 PM | #4 | |
May 16th, 2013, 08:38 PM | #5 |
May 17th, 2013, 08:28 AM | #6 |
May it be from the plug of the oil refill hole on the clutch cover?
That big plug-bolt is about 1" diameter and it has an O-ring. http://thumbs3.ebaystatic.com/d/l225...diTBjCe0Iw.jpg
May 17th, 2013, 09:07 AM | #7 |
Of the top of my head, that's probably it. From what I remember it's EXACTLY the size of the oil fill cap.
If it fell out with the oil screen though, that means i've had an o-ring floating around in my oil, which probably is an awful thing, right lol? I'll walk outside here in a little bit and check to be sure. Also I rode for a little bit today, no leaks, no problems, shifting is a little bit smoother. |
May 17th, 2013, 09:12 AM | #8 | |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
May 17th, 2013, 09:20 AM | #9 |
Attached is where it's located. Not the same as oil filter media.
May 17th, 2013, 09:38 AM | #10 |
sail away
Ah thanks for the picture, I recognize this now.
May 17th, 2013, 10:01 AM | #11 |
Yes, ............especially for the O-ring !!!
May 17th, 2013, 11:55 AM | #12 |
Oh okay, well now I know it wasn't just circulating in the system...whew!
Idk how it could fit over that oil screen. I tried to stretch it but it was really inelastic, much less so than the two oil filter o-rings (or so I thought). Well lets hope there's no problems. I'm not draining the oil again if I don't notice any issues lol |
May 17th, 2013, 04:16 PM | #13 |
Good thing you checked the oil screen. More than likely, its the o-ring from the filler cap like motofool said. However, I think there are also large o-rings of that size that are used by the water pump. But since you have no leaks and nothing strange about your oil or coolant, then its most likely the filler cap o-ring. Bottom line: Don't worry about it if there isn't a problem. A rubber o-ring is one of the few things that can be dropped in the oil filler and not cause damage.
does the 300 have a oil screen? | felo | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 7th, 2023 08:00 AM |
Where is the Oil Screen? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 1st, 2023 10:12 AM |
Oil filter's small o-ring doesn't fit | asdfman | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 21st, 2015 10:32 AM |
Oil filter o-ring different sizes?? | arncliffe | 2008 - 2012 Ninja 250R Tech Talk | 4 | December 31st, 2014 06:18 AM |
Riddle me this: oil screen | cuong-nutz | General Motorcycling Discussion | 4 | February 23rd, 2013 11:03 AM |
