Old January 12th, 2010, 10:00 PM   #1
Diablita
Motorcycle(s): '08 Ninja 250r (race)
Question Racing chains?
Anyone able to recommend/or that has used a good lightweight, light drag racing chain in place of one with rings?
Diablita is offline   Reply With Quote
Old January 12th, 2010, 10:21 PM   #2
Someone looking for similar info in this thread, haven't used anything but that stock 250 chain at this point myself.
Old January 12th, 2010, 10:49 PM   #3
2WheelGuy
2WheelGuy's Avatar
Just about everyone in the AFM, myself included, runs a 428 chain and sprockets.
AFM #278
Old February 19th, 2024, 02:37 PM   #4
oldnewninjarider
Motorcycle(s): EX250F
@2WheelGuy , how long should a maintained quality 428 light chain/light sprocket set last on the street on a relatively lightweight pregen, and where could one get one? Looking for performance, don't see a lot of mileage.
oldnewninjarider is offline   Reply With Quote
Old February 19th, 2024, 02:44 PM   #5
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
So for racing use unsealed chain for minimum losses. For the road use an X-ring chain. No real benefit on the road to a race chain or smaller than stock size, it will just wear quicker.
Quality 520-X-ring chain & sprockets should last at least 20K miles. An old trick we used as couriers was to buy 2x front, one rear & a new chain. Front always wears quicker, so we would swap it halfway through chain life.
Old February 19th, 2024, 03:41 PM   #6
2WheelGuy
2WheelGuy's Avatar
Those chains don't last long at all. They need constant lubrication, adjustment, and replacement. I would not run one on the street.
On the track the lighter weight may get you a few feet on the guy next to you over the course of a lap. On the street you won't even notice the difference.
Sprocket Specialists make the sprockets. You can get order the chain from any place that sells chains. Get the highest tensile strength quality chain you can find.
AFM #278
Old February 20th, 2024, 06:54 AM   #7
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
MX sealed chains - lighter than the best racing 520 sealed, cheaper, and plenty strong
Old February 26th, 2024, 01:34 PM   #8
oldnewninjarider
As work on it and replace things, looking to take weight esp rotating and unsprung off the bike wherever can, including battery, exhaust, lights, tires, flywheel, clutch, sprockets, chain etc so it all adds up, but keeping balance of reliability.
Would you have a link or one you'd recommend? And with which lighter sprockets?
Last futzed with by oldnewninjarider; March 3rd, 2024 at 07:55 PM.
Old February 28th, 2024, 09:14 AM   #9
sharky nrk
sharky nrk's Avatar
GB520MXU is what I use with renthal sprockets.
Old March 5th, 2024, 01:26 PM   #10
oldnewninjarider
Aluminum rear? How does it compare weight and rolling resistance vs stock, and how does this setup wear/long does it last you?
Old March 6th, 2024, 07:49 AM   #11
sharky nrk
sharky nrk's Avatar
Yeah, aluminum rears on the race bike. Steel superlights on the street bikes. Honestly can't say on the lasting since gearing changes a bit from track to track and I can't say that do a good job tracking it lol.
Old March 6th, 2024, 08:49 AM   #12
Depending on what aluminum alloy it is, an aluminum rear sprocket can last a long time in street use. I put 30,000 miles on one that still shows nearly no wear. I do keep my chain lubed properly.
Old July 16th, 2024, 12:08 PM   #13
petrolhead
I've stuck to stock parts. Fairly good availability with different sprockets.
petrolhead is offline   Reply With Quote
How long do you go between new chains? agentbad 1986 - 2007 Ninja 250R Tech Talk 13 November 25th, 2014 02:53 PM
All about chains Sirref 2013 - 2017 Ninja 300 Tech Talk 27 September 1st, 2014 10:33 AM
Any others using Silicone on their chains caltony General Motorcycling Discussion 1 May 21st, 2014 07:07 AM
Chains? quadcrazy 2013 - 2017 Ninja 300 Tech Talk 2 January 22nd, 2014 06:03 PM
Question about chains Sailariel 2008 - 2012 Ninja 250R Tech Talk 2 September 30th, 2008 05:46 PM
