February 23rd, 2010, 05:53 PM | #1 |
Join Date: Feb 2010 Motorcycle(s): 02 SV650 07 Ninja 250 Posts: 5
Have a lean issue with my bike, issue with coasting enricher.
Okay so i have been chasing a stumble after a rev or rocking the bike forwards and back. When I spray carb cleaner at the Coasting enricher the idle raises. Ive pinpointed it to the big top tube on the valve. What does this hose do? When I pinch it at about 2 inches back it raises the idle. Is this because im fixing a vacuum leak or because I am disabling the coasting valve?
Thanks for taking the time to read this! Darren |
February 23rd, 2010, 06:01 PM | #2 |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
You've got a vacuum leak in the coasting enricher. The diaphragm is probably torn. For now you can just plug the hose to stop the vacuum leak. The bike just might pop a little on deceleration.
Here is info. on the coasting enricher: http://faq.ninja250.org/wiki/How_a_c...a_Closed_Mouth
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
February 23rd, 2010, 06:04 PM | #3 |
ive removed the diaphragm and it looked good. What does the big hose on top do, do you know?
February 23rd, 2010, 06:14 PM | #4 |
The big hose is a vacuum line. The level of vacuum tells the enricher if the bike is coasting or not. The vacuum leak is why your bike isn't idling properly.
February 23rd, 2010, 06:40 PM | #5 |
so what can leak in that part. The little o ring couldnt be the culprit right? It would have to be the diaphragm?
February 23rd, 2010, 06:55 PM | #6 |
Not much to leak but the diaphragm. Or the housing is cracked or not sealing to the diaphragm. Or the hose just isn't on tight.
February 23rd, 2010, 06:57 PM | #7 |
okay i will stop bothering you now, I will take the tank off tomorrow and start inspecting. Thanks for the advise!!
February 24th, 2010, 06:54 PM | #8 |
okay so i was messing with it tonight. when i plug the line it runs good for a sec then starts to bog down. if i take both rhat line andthe manifold line that goes to it and plug them off they do the same thing asbefore. any ideas?
Posted via Mobile Device |
New Guy, New Bike- Drivetrain issue | biblefreak | 1986 - 2007 Ninja 250R Tech Talk | 25 | April 7th, 2015 03:08 PM |
bike idle and throttle issue | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 18th, 2015 04:53 PM |
Bike issue | checho323 | General Motorcycling Discussion | 3 | July 17th, 2014 10:21 AM |
Coasting enricher, what pipe goes where? | RBN | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 9th, 2013 02:45 AM |
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 07:50 AM |
