Old June 26th, 2024, 07:00 AM   #1
Nbuck7
Motorcycle(s): 2008 Ninja 250
Gas Tank Questions
Hey,
I bought a 2008 ninja 250 as a project bike. Have a couple questions about the gas tank.
First of all, there is a nipple on the bottom left side of the tank, pictured below. When I add gas to the tank some will drain out of it. Should that be capped or is there a hose that's supposed to be attached?
Second, the petcock is different from other 2008-2012 ninjas. It has off, on, and reserve. No "pri". It only has one hose attachment, so no vacuum hose. Someone must've replaced the petcock. Do I need to buy a new one with a vacuum attachment? If not, should I just plug the spot on the carb where the other end is supposed to go?
Thanks.
Nbuck7 is offline   Reply With Quote
Old June 26th, 2024, 07:52 AM   #2
Doesn't that nipple connect to a drain hole under the gas cap so fuel doesn't sit there if you overfill the tank? I don't have a newgen to look at.
If you keep the manual petcock, yes, plug the vacuum port on the carb that originally went to the vacuum petcock. Since it's a manual petcock, there is no need for a "prime" position, since turning it on lets fuel flow immediately.
Old June 26th, 2024, 06:34 PM   #3
Nbuck7
Ah that would make sense about the gas cap. I'll take a look.
Gas issues, Gas tank questions F9zSlavik 1986 - 2007 Ninja 250R Tech Talk 7 February 11th, 2020 01:39 PM
Gas tank questions ?? SlowpokeNinja 1986 - 2007 Ninja 250R Tech Talk 4 April 10th, 2017 10:40 PM
08+ Ninja 250 CA model Gas tank port questions (Evap System Removal) abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 April 3rd, 2012 09:59 PM
gas in oil questions BIGT94z 2008 - 2012 Ninja 250R Tech Talk 9 September 22nd, 2010 03:12 PM
Noob gas questions AgentCircus 1986 - 2007 Ninja 250R Tech Talk 11 September 6th, 2010 05:35 PM
