March 4th, 2011, 08:05 PM | #1 |
Join Date: Dec 2009 Motorcycle(s): Ninja 250R Posts: 432
sprocket position?
I revomed my front sprocket and didn't pay attention when I was doing it. Now I noticed that each side of the sprocket is different, one side is flat and the other side has a collar or whatever is called. So my question is, which side is suppose to be facing out?
Thanks in advanced. |
March 4th, 2011, 08:28 PM | #2 |
collar side in.
March 4th, 2011, 08:33 PM | #3 |
March 4th, 2011, 10:27 PM | #4 |
GDTRFB
Join Date: Nov 2010 Motorcycle(s): 2009 Ninja 250 - sold 2005 EX500R project Posts: 496
Master Kelly,
I got a 15t sprocket today and wanted to throw it on (and also ride before it got dark). Anyone run into an issue with getting the sprocket cover off? I have the shop manual and can see that it should easily come off. I just decided to take advantage of the day and go riding the gap so i put the bolts back in and went. |
March 4th, 2011, 11:43 PM | #5 |
Drew,
The sprocket cover can get "glued" on by the excess chain lube that gets flung up under there. After removing all the bolts for that cover, give it a smack with a piece of 2x4 held up against it and a hammer. That should loosen the cover. how did you know I worked in a bait shop? |
March 5th, 2011, 10:00 AM | #6 |
GDTRFB
Great, thanks Kim.
I just needed a little more "persuasion" to get the cover off. Good thing I had a breaker bar and extension. The nut holding the sprocket was like welded on! Cheers |
JT Sprocket 42 tooth Rear Sprocket | lolibater | Motorcycle-related | 36 | February 25th, 2013 12:30 PM |
