Old July 30th, 2010, 10:23 AM   #1
AgentCircus
I'm getting new fork seals tomorrow. What oil level should I use?
I'm taking my bike in tomorrow to get the fork seals changed. I've heard that the recommended stock oil level for our bikes is too low at 205mm, and I've seen 130mm and 115mm recommended as something that would work better.
For a rider like me who's 5'3", 125 lbs. what level would you guys recommend and what oil weight?
Thanks a bunch!
Last futzed with by AgentCircus; July 30th, 2010 at 04:23 PM.
AgentCircus is offline   Reply With Quote
Old July 30th, 2010, 11:01 AM   #2
How much is this costing you? I think I need mine done.
Old July 30th, 2010, 11:13 AM   #3
Cuongism
Cuongism's Avatar
Oil weight depends on where you live (I'm on mobile so I can't see people's location). Warmer weather, lighter weight, colder weather heavier weight. I have a 08 new gen and my service manual says 8W (which I'm not sure it exists but you can mix 10W and 5W accordingly). I changed my seals today and used 10W which makes it a little stiffer but I also weigh more than you but I also know people who use 5W (I live in southern CA). If you're replacing the fork seals, you'll be disassembling everything and cleaning all the parts, so you can measure both forks by volume since it's dry weight vs measuring from the top of the tube. Just make sure both sides are the same. For my 08 version, the recommended by Kawasaki is 12.2 ounces dry, but I'm not sure for your version. I would imagine you would want softer suspension though since you're light.
Posted via Mobile Device
Old July 30th, 2010, 11:15 AM   #4
2WheelGuy
2WheelGuy's Avatar
I run 5" from top compressed, springs and emulators out on all my 250s. About 130mm.
I run 15w oil on my new-gen which is track only.
AFM #278
Old July 30th, 2010, 01:01 PM   #5
AgentCircus
Originally Posted by czroe View Post
how much is this costing you? I think i need mine done.
$200
Old July 30th, 2010, 01:01 PM   #6
AgentCircus
How much do you weigh?
For the street, do you think I'd be okay with 10w oil, 130mm?
Old August 1st, 2010, 11:24 AM   #7
AgentCircus
EX500 Springs
After doing a little research, I think EX500 springs would be perfect for me. Labor won't cost me anything extra since they have to remove everything to change the fork seals anyway.
My question is, if I do change the springs - would I still add more fork oil? Is there anything else I need to buy besides the springs? Or is it a plug and play type of deal?
Old August 2nd, 2010, 08:13 AM   #8
shortstuff
Motorcycle(s): 08 250
I'm 5'1, 125 and used 12.2 oz of 5W when I took my forks apart. I'd be curious what the front end would feel like with an 8W (pure or combined 5 and 10) but that's keeping it stock. After talking with some guys in the shop, you'd really feel the difference between 5W and 10W when you're doing heavy breaking. I'd think if you're putting in stiffer springs that you'd want to keep the oil on the lighter side unless you're going to be doing high-performance stuff (like racing)
shortstuff is offline   Reply With Quote
Old August 12th, 2010, 02:04 PM   #9
longhorn
For what it's worth; the official Kawasaki spec sheet calls for SAE 10W20 oil at 226+/-2mm.
longhorn is offline   Reply With Quote
DIY- Replace fork seals, dust seals and fork oil shortstuff 2008 - 2012 Ninja 250R Tech Talk 212 November 6th, 2023 10:53 AM
Fork oil level Sipper' 1986 - 2007 Ninja 250R Tech Talk 1 June 25th, 2014 04:08 PM
Fork / dust seals from EX500 D Graugaard 2008 - 2012 Ninja 250R Tech Talk 2 February 4th, 2013 10:33 AM
Fork oil level: with or without springs? RedOctober 2008 - 2012 Ninja 250R Tech Talk 5 April 16th, 2012 02:06 AM
Help Wanted: Fork Oil & Seals Replacement in San Jose, CA rurugger Group Rides and Local Events 5 October 18th, 2009 10:39 PM
