June 24th, 2024, 04:52 PM | #1 |
Join Date: Jun 2024 Motorcycle(s): 2008 Ninja 250 Posts: 30
2008 ninja 250 float valve needle plunger
Hello,
I'm cleaning the carbs on my 2008 250 project bike. Noticed both floats were pretty off, at around 22 mm. Manual says 17 mm. When I adjusted the tangs I realized I had to bend them pretty far down to get close to 17, and that resulted in the floats barely being able to move up and down. I don't think it's correct. Noticed that, in contrast to my TW-200 carb I'd worked on, the little plungers on both fuel needles that the floats sit on were fixed in place. On my TW the plunger would go in and out as the float moves up and down on it. Are those plungers supposed to move? If so I can't get them unstuck. Thanks. |
June 24th, 2024, 07:35 PM | #2 |
yes, absolutely
Custom Carb Service |
June 24th, 2024, 07:39 PM | #3 |
Any idea on how I can get them unstuck?
June 25th, 2024, 01:01 PM | #4 |
frankly, I'd replace them....notice the discoloration/differences which have affected the actual viton sealing surface in your pic?
June 26th, 2024, 04:54 AM | #5 |
Ordered a rebuild kit. Thanks
June 26th, 2024, 06:38 AM | #6 |
be aware of inconsistencies of brass tuning components within kits
within my service, i choose to clean/reuse all (correct) brass where possible .....consistently replacing all "consumables" (orings, float valves) Fully your choice though.
June 26th, 2024, 06:53 AM | #7 |
Gordon put it politely. All rebuild kits I've ever gotten or heard about have non OEM jets that will keep you working on the carbs forever. The float needles and gaskets in the kits are usually OK.
June 26th, 2024, 07:01 AM | #8 |
Good to know.
2 Carb Questions - O-Rings and Float Valve | wfsdno | 1986 - 2007 Ninja 250R Tech Talk | 2 | May 30th, 2024 05:45 PM |
New Gen Valve Float | Ram Jet | 1986 - 2007 Ninja 250R Tech Talk | 3 | July 7th, 2018 07:50 AM |
Need help asap with float needle height | M42 | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 24th, 2014 01:14 PM |
ninja 250 float problem? | xbox3bob | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 10th, 2012 06:05 PM |
Carb - leaky float valve questions | ako | 1986 - 2007 Ninja 250R Tech Talk | 34 | June 15th, 2011 10:04 AM |
