Old September 12th, 2014, 04:13 PM   #1
Espinoza07
Won't start
So, I changed the oil when I saw that it was really low. Now I'm thinking I need to change the plugs.
But when was trying to start it up today, it won't kick on. The longer I would hold the starter button, the lights go dim and the power got really weak, then nothing. I just put a new battery in yesterday so i know it's not that. But is it the alternator now since what I just describe is happening?
Espinoza07 is offline   Reply With Quote
Old September 12th, 2014, 04:25 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Could still be the battery, charge it then try again.
Old September 12th, 2014, 04:32 PM   #3
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Yeah, always charge a new battery before putting it in - could have been sitting on the shelf a while.
M42 is offline   Reply With Quote
Old September 12th, 2014, 07:48 PM   #4
Finesse
ran when parked
Finesse's Avatar
Motorcycle(s): Freeride 250R, KLX250SF, mopeds
MOTM - Sep '17, Dec '14
Third opinion on the battery issue, did you actually put a fully charged battery in, or a
new one right out of the box? Usually the ones OTB are not fully charged. Make sure the battery is charged before you go fussing with the alternator, which hardly ever ever ever fails in this bike so it seems....
Finesse is offline   Reply With Quote
Old September 14th, 2014, 06:47 PM   #5
Espinoza07
Ok I charged the battery
To 100% and the bike still not turning over. Plus it did the same thing.. The cluster went dim and then heard a clicking noise.. Alternator right?
Also, could it be that I haven't cleaned the carburetor since it's been sitting for so long?
Old September 14th, 2014, 07:05 PM   #6
Flying
Motorcycle(s): 2010 Ninja 250
Clicking = Battery has power going to solenoid which isn't turning over the starter motor (which it should be).
I would be worried about the alternator if you had your problems while the bike is running, not at startup.
Old September 14th, 2014, 08:07 PM   #7
Still sounds like a battery problem to me. You can get a "full charge" reading from a charger and still have a bad battery.
Check the voltage - 1st before you crank, 2nd while you are cranking.
A fully charged battery will read 12.7V before cranking. When you hit the button you should still see 11V or above while the starter is turning. If you get less, and the battery showed 12.7 before hitting the button, there's an internal problem with the battery - not uncommon.
It's also not uncommon to need to charge a low battery for 8 to 10 hours (at the correct rate for its size) in order to get it 100% charged. When you take it off of the charger it will read higher, but should settle down to 12.7V after sitting a while.
Won't start... :( HELP! deeno415 1986 - 2007 Ninja 250R Tech Talk 59 August 31st, 2013 05:53 PM
Bike won't start sLick415 2008 - 2012 Ninja 250R Tech Talk 7 February 4th, 2013 11:38 PM
Bike won't start Z300 2008 - 2012 Ninja 250R Tech Talk 21 August 26th, 2012 09:05 PM
Bike won't start joyinc 2008 - 2012 Ninja 250R Tech Talk 21 May 31st, 2010 09:10 AM
Won't start Momaru 2008 - 2012 Ninja 250R Tech Talk 15 August 9th, 2009 09:48 PM
