Old September 19th, 2012, 03:40 PM   #1
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
Looking for first time Pregen maintenance tips
Hi everyone. I'm about to do my first maintenance on my Pregen this Saturday. I will be doing the following tasks:
- Oil change
- Clean oil screen
- Coolant flush
- Brake fluid flush
- SS brake line install
- Replacing shift shaft oil seal
- Change spark plugs
- Adjust valves
Does anyone have any tips, either model specific or general, that will make this easier for me? Anything to clean and/or check while I'm in any of those places? Thanks.
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old September 19th, 2012, 04:02 PM   #2
93etgocart
93etgocart's Avatar
Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250
clean and lube your chain, also since you will have the bike apart already scub anything you cant normally get to when you wash it.
93etgocart is offline   Reply With Quote
Old September 19th, 2012, 04:13 PM   #3
lolibater
lolibater's Avatar
I surely will be scrubbing and washing anything I can. I hear lots of nasty **** piles up under that front sprocket cover. That should be interesting lol.
Old September 19th, 2012, 04:20 PM   #4
valve job.
Old September 19th, 2012, 04:25 PM   #5
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Be sure to change the oil filter
AFM #676
Supersports are for n00bs
Old September 19th, 2012, 04:31 PM   #6
lolibater
lolibater's Avatar
Yep, i got the filter and all gaskets and washers here already.
I was more looking for specifics as to how any of the tasks I listed might be accomplished easier or faster? Any typical issues I might run into that as a first time worker, might not know about?
Old September 19th, 2012, 05:05 PM   #7
EMSRacer07
EMSRacer07's Avatar
Take the fairings and tank off the night before so you wont have to deal with it the next day.
Valve job: to make it easier if you if you can get the right side coil bracket off. You wont have to take off the radiator or even move it to get the valve cover out. If u can remove that bracket (its two bolts and a spot weld the size of a bb). Make my valve job alot faster.
Spark plugs: Use anti sieze and make sure to install them correctly, meaning dont over tighten them but get them to sit in right.
Everything else is straight forward on doing the coolant flush and break fluid. Would be easier if you had everything on the center stand for sure.
Old September 19th, 2012, 05:49 PM   #8
For coolant flush, don't forget the drain that's right under the head on the front of the engine.
idk if you've done a coolant change before, but it's not bad. It helps to have a second person there so you can watch the radiator bubble while the bike runs. It only takes a minute to get the bubbles out.
For the SS brake lines, use a lot of force when compressing the brake lever. It will force the air bubbles out of the lines better. The whole process of bleeding air out of the lines takes about a minute once you figure out what the heck you're doing.
Old September 19th, 2012, 07:38 PM   #9
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
bleeding new brake line
http://www.zggtr.org/index.php?topic=5058.0
GeorgeRYoung is offline   Reply With Quote
Old September 19th, 2012, 07:48 PM   #10
Jono
Jono's Avatar
Your gonna have a fun weekend! I enjoy working on my bike. Ummm don't drop your feeler gauge. Haha. My first valve adjustment went well until I dropped a feeler gauge and it feel down the opening by the cam chain. Luckily I was able to get it out after removing the clutch cover. But it sucked.
Old September 20th, 2012, 02:32 AM   #11
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Make sure to bookmark this page:
http://faq.ninja250.org/wiki/Main_Page
Old September 20th, 2012, 03:24 PM   #12
lolibater
lolibater's Avatar
Also, how important are the following:
- Replacing fork oil
- Getting suspension "adjusted" for my weight?
- Lubricating swingarm pivot
Old September 20th, 2012, 05:16 PM   #13
Swingarm maintenance, do it!! Makes the back end smoother. Worth the time.
I swapped to a little thicker oil when I had my fork seals replaced. Seems a little better.
There's really no tuning for your weight on the pregen shock
Old September 21st, 2012, 05:50 AM   #14
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
If you're gonna do that, buy some correct-sized springs from Racetech and cut some new spacers. It will make a world of difference.
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
First Time Maintenance Kruse08 1986 - 2007 Ninja 250R Tech Talk 36 December 27th, 2014 02:55 PM
I'm at 6k miles, time for maintenance? Sykes92 2008 - 2012 Ninja 250R Tech Talk 5 March 22nd, 2014 11:15 AM
[motorcycle-usa.com] - Harley-Davidson Offers Tire Maintenance Tips Ninjette Newsbot Motorcycling News 0 February 19th, 2014 12:20 PM
FS: The Essential Guide to Motorcycle Maintenance: Tips & Techniques to Keep Your Mot Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
Pregen racer setup tips/hints??? Jiggyfly Ninjettes At Speed 6 March 29th, 2012 09:26 AM
