Old June 16th, 2013, 12:17 PM   #1
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
the 300 dollar ninjette came with issues
So I bought a 300 dollar 05 ninjette last weekend( couldn't pass it up) and it seemed quite solid and only been standing for like 6 months; fast forward to today, after draining the tank and charging the battery, I fired it up and worked fine and warmed up ok, changed the oil after it was warm along with filter and plugs, assembled it back, and it fires up waaaaaaay better except for the fact that I kept smelling gas, looked down and I'm standing in a small pool of fuel!!!! Seems the fuel overflow tube is leaking like crazy, is this normal or is there something seriously wrong with it?
cerberusrex25 is offline   Reply With Quote
Old June 16th, 2013, 12:31 PM   #2
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Are you talking about the tube coming from the carbs, or the gas tank?
Old June 16th, 2013, 12:33 PM   #3
Educated guess but sounds like carb overflow, check the floats and float valve.
Old June 16th, 2013, 12:39 PM   #4
cerberusrex25
Accesories Guru
carbs one.
any idea on how to do this?
Old June 16th, 2013, 01:12 PM   #5
You need to remove the carbs. Once off, remove the bowls. Under the bowls in each carb there are 2 large cream colored floats connected to a small valve. Basically, when the bowls are full, the valves are closed. If the valves never close the carb will flood and overflow.
Might as well clean the whole carb since you have it out. When you take out the floats, be careful to no bend the little wires that operate the valve pin. Also, remember to replace all the carb screws with hex head while you have it out. If you do a quick search on youtube, there are some great videos for "ninja 250 carb cleaning". Newgen or pregen, the cleaning process is basically the same.
And I am sure @Motofool will be here shortly with some great links to removal, cleaning and such. He is great for that. But I am a video person myself.
Ask if you need or have any specific questions. I will be happy to help as best I can.
Old June 16th, 2013, 02:24 PM   #6
drc84
Motorcycle(s): 2004 EX250
Here's a great video on this:
I used this one liberally when I worked on my carburetor. As in, I would do one step, pause the video, do the next step, pause the video.
In fact, I used this one as well:
I would switch back and forth between the two and also use the guide found here: faq.ninja250.org. I have used those three things when cleaning my carbs twice.
drc84 is offline   Reply With Quote
Old June 16th, 2013, 03:33 PM   #7
Exactly like Chris has explained it.
There are few reasons for the valves not closing the flow of gas into the carbs once the proper level is reached:
-Harden neoprene of the tip of one or both valves.
-Debris between the valve and the seat.
-Punctured float.
-Level set too high.
Check this links:
http://faq.ninja250.org/wiki/How_do_..._the_floats%3F
http://faq.ninja250.org/wiki/What_ca...ed_to_check%3F
http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F
Old June 16th, 2013, 03:54 PM   #8
cerberusrex25
Accesories Guru
Thanks guys, those were great vids, but none of these explains how to regulate the floaters level, I'm gonna clean them but it seems this won't solve my leak.
Old June 16th, 2013, 03:56 PM   #9
cerberusrex25
Accesories Guru
-Punctured float.
Check this links:
Thanks motofool, this is quite helpful.
Old June 16th, 2013, 04:09 PM   #10
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
$300 and that's the only issue you have? And it starts?!?! Wow....
You can regulate the float height by adjusting the metal tangs attached to the float valves. A high float = more fuel and vice versa...
Old June 16th, 2013, 04:20 PM   #11
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Probably gunked up carbs. Too complicated, sell it to me for $300.
My Cafe Racer Build
My intro post
Old June 16th, 2013, 04:23 PM   #12
FvnnyL3tt3r1ng
Ignore him, I've got $350 cash in hand.
Old June 16th, 2013, 05:10 PM   #13
cerberusrex25
Accesories Guru
Anyone got 400? LOL, yeah so far that is the only issue. The only reason I got it for 300 is because the dude's fiance was all up in his business to sell it, so he let it go for that price because of that and the threat of getting it towed for having expired tags( apartment complexes around here are quite the dicks about it).
EDIT: I'm dumb and had forgotten about my Clymer manual, it has everything you need to fix this little problem, and amazing diagrams. Best 25 bucks I've ever spent, thanks to all that shed a light on the problem, I will keep you updated on the results after I take them apart this weekend.
Last futzed with by cerberusrex25; June 17th, 2013 at 06:37 PM.
Old June 19th, 2013, 04:27 PM   #14
Lychee
sail away
Lychee's Avatar
350.01
Old May 26th, 2014, 09:07 PM   #15
Originally Posted by Lychee View Post
350.01
The Price is Right.
Old May 26th, 2014, 09:10 PM   #16
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
This right here! Lol I need to find a deal like this for my winter build!!
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Help me find this and I will paypal you a dollar shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 7 May 1st, 2012 08:37 AM
What is the point of dollar bills all over your cluster? WhiteRice General Motorcycling Discussion 26 October 11th, 2011 12:08 PM
$25 dollar leather jacket dk58 Gear-related 71 July 25th, 2011 03:08 PM
Ninjette is having fueling issues AncientTV 1986 - 2007 Ninja 250R Tech Talk 29 April 10th, 2011 02:58 PM
Missing Dollar n4t Off-Topic 11 June 2nd, 2009 06:44 AM
