Old March 25th, 2009, 02:04 PM   #1
Octane, Money and You??? What do you run in your 250 and why?
I use 87 octane gas. It is what is recommended for my 08 250R.
Old March 25th, 2009, 02:08 PM   #2
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
I run 87 octane too. I don't know for sure whether it's reccommended in pregens, but I'm a cheap son-of-a-gun, so I buy what's cheaper! Runs great, so I don't think it's a problem.
Verus Cidere is offline   Reply With Quote
Old March 25th, 2009, 02:09 PM   #3
87 is what is recommended for the pregens, too.
Old March 25th, 2009, 02:15 PM   #4
Snake
Snake's Avatar
I always run 87. I tried running premium in the past and found that my gas mileage sufferd and performance did not improve.
Old March 25th, 2009, 02:16 PM   #5
Verus Cidere
Ok. Really quick qestion then: Why do all the new bikes have stickers that say use 90+ octane to keep from causing severe damage to the engine? I noticed that while checking some things on an 09 here. Is it just a trick to make you pay more for gas?
Old March 25th, 2009, 02:18 PM   #6
where are the stickers located and is it a factory Kawasaki sticker or something the dealer had printed up?
Old March 25th, 2009, 02:23 PM   #7
Verus Cidere
I don't know if it's just from the dealer or not. It's right on top of the tank, just below the gas tank. It says "Important - Use only 90+ octane gasoline to avoid causing serious damage to engine." I thought it was full of crap, but wanted to make sure. I guess it could be a dealership thing? I know I saw it on all of the new Kawi bikes, but I didn't check the Suzuki or Honda (it's a 3 brand dealership).
Old March 25th, 2009, 02:32 PM   #8
zeroth
weekend rider
zeroth's Avatar
Motorcycle(s): '05 Ninja 250
I run 87 too. Recommended for the Ninjette, plus I've read that unless you get knocking (on any vehicle, even one which recommends higher), there's no point going higher.
zeroth is offline   Reply With Quote
Old March 25th, 2009, 02:36 PM   #9
did you read closer to see if it said 90+ octane RON or PON?
http://www.btinternet.com/~madmole/R...RONMONPON.html
if it's 90+ RON, that's the same as our US gas 87 octane PON.
Old March 25th, 2009, 02:40 PM   #10
hieuster
hieuster's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
I use 87 octane on mine from either chevron, shell, or exxonmobil. Don't really see the point on using higher octane unless I have a turbo on my bike lol.
Hmm, I don't see the sticker requiring 90+ octane on mine, but I have seen that sticker on other bikes especially the high performance super sport bikes.
hieuster is offline   Reply With Quote
Old March 25th, 2009, 02:45 PM   #11
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Can you grab a picture of the sticker. I just got my '09 in Feb and there is NO sticker as you've described.
And I feed her 87
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old March 25th, 2009, 02:52 PM   #12
Verus Cidere
I might be able to get a pic. I don't actually have a camera at the moment though. I'd have to borrow someone else's (which is what I do for any pics I'll have unless I get them off the internet). I'll see what I can do.
Old March 25th, 2009, 03:18 PM   #13
HKr1
IC2(SW)
HKr1's Avatar
Baby ninja gets 93. I fill up the R1 & just hand the nozzle over
Old March 25th, 2009, 03:24 PM   #14
bah... fill up the ninja first, then fill the R1 w/ 87.
Old March 25th, 2009, 03:26 PM   #15
paterick4o8
paterick4o8's Avatar
Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636.
I use 91 occasionally I guess just to help clean the engine. Probably doesn't do anything but eh, it's Costco 91 so it's about the same price between 87 & 89 at regular stations
paterick4o8 is offline   Reply With Quote
Old March 25th, 2009, 03:28 PM   #16
you are correct, it does do that, but so does the 87 & 89.
Old March 25th, 2009, 03:30 PM   #17
paterick4o8
Costco 87 it is from now on then , unless I hear some knocking I guess
Old March 25th, 2009, 03:39 PM   #18
yes, knocking is the "litmus" test.
not saying not to use the higher octane, but there is no benefit for our bikes other than lightening your wallet. save your money for some cool mods, instead... or synthetic oil.
Old March 25th, 2009, 03:39 PM   #19
GTsmokeya
GTsmokeya
GTsmokeya's Avatar
Motorcycle(s): 04' Silver 250 Ninja
I have read high and low about what gas to use in the 250 and the average is 87 octane. I hear running a higher octane makes the motor run to rich. In reality higher octane gas burns at a higher temp which could change certain characteristics of the motor. In my car however I run Prem. octane in it, and car motors are usually more refined and controlled, I notice it idle smoother and has quicker pick up.
GTsmokeya
GTsmokeya is offline   Reply With Quote
Old March 25th, 2009, 03:40 PM   #20
Ken
"Is that the Ninjer 1000?
Ken's Avatar
Motorcycle(s): 2008 Quarter Liter Kawi
If the engine is tuned to run on regular you won't benefit from using premium. In a nutsell the higher the octane the slower it ignites so when your piston moves up to Top Dead Center (TDC) for combustion, using premium fuel may reduce power and fuel economy- unless you advance timing and/or increase compression via taller pistons.
My Mods
Ken is offline   Reply With Quote
Old March 25th, 2009, 03:47 PM   #21
HKr1
IC2(SW)
HKr1's Avatar
Little ninja is 11.5:1, it can have the 93
Old March 25th, 2009, 04:11 PM   #22
Rawr
Blue Blue Blue
Rawr's Avatar
Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R
i have always filled up with premium...just looked at the label information in the owners manual....it says Gasoline With Reasearch No. (RON) 91 Min.
so this is normal 87 yes?
Rawr is offline   Reply With Quote
Old March 25th, 2009, 04:13 PM   #23
yes, same as US market 87.
Old March 25th, 2009, 04:15 PM   #24
Rawr
Blue Blue Blue
Rawr's Avatar
just looked in owners manual again...under gas tanks section...says use 87 MINIMUM....so would there be no harm in using higher?
Old March 25th, 2009, 04:18 PM   #25
nope... no benefits, either.
Old March 25th, 2009, 05:17 PM   #26
sometimesido
sometimesido's Avatar
Motorcycle(s): 2006 250R
87 Octane, as recommended. No knocking.
Some of you guys should read this about Octane.
http://faq.ninja250.org/wiki/What_ki...hould_I_use%3F
my flickr™
sometimesido is offline   Reply With Quote
Old March 25th, 2009, 05:21 PM   #27
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
Shell 87 all the time. Though I've dumped in some v-power into the 06 when it was hesitating and needed some cleaning
Nemy is offline   Reply With Quote
Old March 25th, 2009, 06:36 PM   #28
Moo-wasaki
Moo-wasaki's Avatar
Motorcycle(s): 2008 Ninja 250
87 too!
Moo-wasaki is offline   Reply With Quote
Old March 25th, 2009, 07:13 PM   #29
djpharoah
\m/
djpharoah's Avatar
Motorcycle(s): CBR600F3 Smokin Joes
Chevron 87. No need for anything higher.
djpharoah is offline   Reply With Quote
Old March 25th, 2009, 08:05 PM   #30
smcbride11
smcbride11's Avatar
Motorcycle(s): '95 BMW K75
I use 87 also, since that's what the manual commands.
I read in Rider this month that at altitude you'll sometimes find 85.5 (Eastern MT in particular), but that it behaves the same as 87 because of the altitude... Not that I plan on being above 10,000 feet anytime soon, but anyone know if there's any truth to that?
smcbride11 is offline   Reply With Quote
Old March 25th, 2009, 08:08 PM   #31
sometimesido
Yeah. I don't have first hand experience, but I read that gas stations up high will sell you that.
my flickr™
Old March 25th, 2009, 08:31 PM   #32
athimmel
athimmel's Avatar
Motorcycle(s): 2009 Ninja 250 - blue
I'm not sure if the higher octane is what caused backfiring in my bike, but since I started using 87 octane regular, I have had no problems. I use Chevron regular.
athimmel is offline   Reply With Quote
Old March 25th, 2009, 09:26 PM   #33
coincidence... as I've always used regular and mine still backfires on occasion.
Old March 25th, 2009, 09:40 PM   #34
azia
Motorcycle(s): 08 Ninja 250
Shell because it's better or for the Airmiles?
I just use 87. I used higher octane to fill out once but then thought to myself, why? Lol.
azia is offline   Reply With Quote
Old March 26th, 2009, 07:36 AM   #35
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
Im thinking the backfires from the higher octane in the bike was unburned fuel...
Cali619 is offline   Reply With Quote
Old March 26th, 2009, 08:40 AM   #36
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
87 will give more HP than 91, as long as there aren't detonation issues. I run 87 in all the racebikes. 87 FTW!!!!!
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old March 26th, 2009, 09:12 AM   #37
athimmel
athimmel's Avatar
I'm sure you're right...but why take chances??
Old March 26th, 2009, 10:47 AM   #38
hey, Rich... you have a few bikes. Do they backfire on occasion when starting up?
Old March 26th, 2009, 11:14 AM   #39
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
Maybe because it is considered "Top Tier" as are all of these:
QuikTrip
Chevron
Texaco
MFA Oil Co.
Conoco
Phillips 66
76
Entec Stations
Shell
The Somerset Refinery, Inc.
Kwik Trip / Kwik Star
Aloha Petroleum
Tri-Par Oil Co.
Turkey Hill Minit Markets
Mileage Stations
Chevron Canada
Shell Canada
Petro-Canada
Sunoco Canada
More Info.
I have always used 87 in the ninjette.
camaroz1985 is offline   Reply With Quote
Old March 26th, 2009, 11:18 AM   #40
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
I use 91 in mine. To me, the money isn't that big of a deal. If 91 is $.10 more than 87, then we're talking about less than $.50 extra a fill-up. So, in a month, I end up spending less that $2 more for 91 and I don't have to worry about knocking. Just my line of thinking...
Matt
2008 Ebony Ninja 250R (a.k.a. "Venom")
Mo1981 is offline   Reply With Quote
[topix.net] - Officials stunned as 94-year-old uses his funeral money to run for parl Ninjette Newsbot Motorcycling News 0 December 13th, 2012 08:40 AM
[topix.net] - Run with Nuns hits the streets to raise money for children Ninjette Newsbot Motorcycling News 0 October 23rd, 2011 06:40 PM
take the money and run.. greatwhiteninja Off-Topic 4 August 4th, 2011 01:49 PM
[crash.net - WSBK] - Haslam: We'll give twins run for their money Ninjette Newsbot Motorcycling News 0 April 8th, 2010 05:00 AM
[crash.net - WSBK] - Haslam: We'll the twins a run for their money! Ninjette Newsbot Motorcycling News 0 April 8th, 2010 03:30 AM
