Old June 22nd, 2009, 11:07 AM   #1
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
Difference between the turn lights??
HI,
I was looking at the 3 turn lights that I have (2 front one rear) and couldn't really tell any difference between them. Can I just but the turn light for any side/location to replace the one that I'm missing or is there a difference that I'm not seeing?
Thanks
divingtigger is offline   Reply With Quote
Old June 22nd, 2009, 12:22 PM   #2
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
are you missing one of your signals? I'm confused about having 3 of them....
according to the parts diagram, there is a difference, though I'm not sure what it would be...
https://www.kawasakiepc.com/SystemSe...TOKEN=55986707
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old June 22nd, 2009, 10:51 PM   #3
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
There is a left turn signal circuit and a right one. There is a total of two incandescent bulbs in each circuit to which I'm pretty confident are the same wattage. You can't add or subtract from either circuit without compensating for the load difference. (So if you add a light in a circuit it'd better be an LED light as the load would be too great for that circuit).
As for Kim, I also don't quite get what the question is about?
VeX is offline   Reply With Quote
Old June 23rd, 2009, 05:06 AM   #4
divingtigger
Pedal Power
Sorry. Here is the full background. I bought an insurance bike that had tons of damage. Both front lights were there and look to be in ok condition. The rear right light was there but the left one wasn't. I thought it was opposite until I started putting some of the pieces where it belongs. I picked up a right hand rear light off ebag thinking that was the one that was missing (most of the damage was on the right side).
Can I use the right rear turn light (the one I bought off ebag) as a left turn light? The harness and plugs are still there it seems like it was just the pod that tore off and when it did it pull the spade style connectors off the light.
Thanks
Old June 23rd, 2009, 05:13 AM   #5
HKr1
IC2(SW)
HKr1's Avatar
Shouldnt be a problem, just different color wire is all.
Old June 23rd, 2009, 10:34 PM   #6
maxedpenny
Don't Be Evil!
maxedpenny's Avatar
Motorcycle(s): 08 250R
I believe that the wires are different lengths, but if its long enough you'll be fine.
maxedpenny is offline   Reply With Quote
Turn Signal lights are acting like hazard lights Greyfox 2008 - 2012 Ninja 250R Tech Talk 13 October 15th, 2014 09:51 AM
Peg turn signal lights. agentbad 1986 - 2007 Ninja 250R Farkles 1 February 14th, 2014 10:34 AM
Wiring LED strips as brake lights, turn signals, and "day-time lights" blackninja18 2008 - 2012 Ninja 250R Farkles 32 August 7th, 2013 03:41 PM
My LED strip turn signal lights .... tc3jg 2008 - 2012 Ninja 250R Farkles 18 January 3rd, 2013 01:43 PM
Turn Signal lights but no blinking Murtasma 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2011 06:06 PM
