Old April 24th, 2016, 04:04 PM   #1
Jenk's
07 Ninja 250 cafe build
Been in the process of building this thing for awhile and i'm getting close to completion now though
Here's an album i created for all my pic so far, go from page 4 to page 1 to see the progression
Let me know what you think
http://s39.photobucket.com/user/bigj...?sort=3&page=4
Jenk's is offline   Reply With Quote
Old April 24th, 2016, 06:05 PM   #2
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I really like the tank. Build is looking great.
My Cafe Racer Build
My intro post
Old April 25th, 2016, 09:55 AM   #3
spent_too_much
spent_too_much's Avatar
That is some fancy tank work! Did I also notoce a 2 into 1 exhaust?
Old April 25th, 2016, 11:53 AM   #4
Jenk's
Thanks ya its tanken awhile
Yep i found the rare yoshi set up but the can was toast so i got a new shiney thing to put on it hah
Old April 25th, 2016, 12:08 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
That muffler may be from Dime City Cycles but it's a Cone Engineering unit. Fantastic (if noisy) little things! Great build quality. I run them too....
Goin' fast on slow bikes!
Old April 25th, 2016, 07:56 PM   #6
Jenk's
oh cool didnt know that, Sweet bike btw Mmmm
Old April 25th, 2016, 08:44 PM   #7
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Might be able to get them cheaper at the source....not sure what Dime City charges.
Old April 26th, 2016, 09:07 AM   #8
liquidnine
Motorcycle(s): 2005 Ninja 250
Hat's off to you, sir. Swapping out the bottoms of the tanks blew my mind. I had a welder repair a hole in my tank (mig) and he kept burning through the thin metal accidentally. It took welding, brazing and solder before the hole was fixed and body filler to make it pretty again. Did you have to do anything special to weld with confidence?
liquidnine is offline   Reply With Quote
Old April 26th, 2016, 05:15 PM   #9
Jenk's
Thankfully it was around the same price but thanks for the heads up
Ya i had a buddy do it, he does welding as a hobby.... but i think he should do it as a profession
Old April 26th, 2016, 05:20 PM   #10
Jenk's
Got the frame cut down and it is getting welded up tomorrow i left the bottom cause i need to work out with my fab guy how to go about mounting the support bars
Old May 4th, 2016, 10:38 PM   #11
Jenk's
Got a lot of stuff done in the last couple of days check it out, starting to look like a cafe bike now
Dad helping me get a visual on what the tail needs to be like
Old May 15th, 2016, 06:50 PM   #12
Jenk's
Got a lot done in a few days even got the bike completed enjoy and let me know what you think, also its for sale so please share this and or let me know if your interested
Old May 16th, 2016, 03:07 AM   #13
spent_too_much
Looks awesome! What type of gas cap is that? Did you end up rejecting the carbs?
Old May 16th, 2016, 03:52 AM   #14
Jenk's
its a weld in flush mount gas cap and i did order new jets but i got the wrong ones, and made it too rich and went back to stock so it still needs some jetting work
Old May 16th, 2016, 07:12 AM   #15
crazymadbastard
Excellent work!
How are you supporting the muffler? I could not see a bracket.
My Cafe Racer Build
My intro post
Old May 16th, 2016, 07:42 AM   #16
spent_too_much
What happens on 04/09/2017??? It is painted on your fence, in the pic of the painted tank.
Old May 16th, 2016, 08:34 AM   #17
Jenk's
sister wanted to do a save the date picture thing on there
Old May 16th, 2016, 08:35 AM   #18
Jenk's
Excellent work!
still working on that .... lol
Old May 16th, 2016, 09:10 AM   #19
crazymadbastard
Me too, that is why I asked.
My Cafe Racer Build
My intro post
Old May 16th, 2016, 09:19 AM   #20
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I had someone TIG weld a bracket to the underside of mine for a mount. Cone engineering mufflers don't come with any so your options are endless! You can also make a bracket that the clamp will go around. Here's a couple ideas from my race bike.
A simple cup bracket from the frame to hold the pipe with a clamp.
All painted up. You can see it on the right, it twists 90 degrees from the frame and has a pipe cut in half for the pipe to rest in.
Old May 22nd, 2016, 07:11 PM   #21
purdy
Motorcycle(s): None yet.
Beautiful bike!!
Where did you get that tank? Please go into detail if possible.
purdy is offline   Reply With Quote
Old May 23rd, 2016, 05:21 PM   #22
crazymadbastard
See page 3 of my build, I tucked an aluminum strip behind the rear 2 master bolts.
My Cafe Racer Build
My intro post
Old May 24th, 2016, 12:48 AM   #23
Jenk's
Originally Posted by purdy View Post
Beautiful bike!!
got the tank from ebay was a kz 1000 or 650 gas tank, had the bottom of the stock tank cut out as well as the kz tank and had a buddy weld in the bottom of the 250 tank to the kz tank so it would fit stock and look retro
Old May 27th, 2016, 01:41 AM   #24
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Nice!!! Im looking for lower handle bars, how'd you do yours?
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old May 28th, 2016, 05:43 AM   #25
Jenk's
Just order some clip ons and slapped them on i think the size is 36mm??
Old May 31st, 2016, 09:09 PM   #26
xXecuterXx2
got it, thanks, clean build btw, ill stick around
Old May 31st, 2016, 09:27 PM   #27
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
2007 Ninja 250 has 36mm forks. Yep!
Old May 31st, 2016, 09:44 PM   #28
Twisthem488
Twisthem488's Avatar
Motorcycle(s): 2009 Ninjette
That is an awesome build. Complete makeover for the little ninjette, and a very sexy one.
Twisthem488 is offline   Reply With Quote
07 Ninja 250 cafe build Jenk's Pictures 1 July 4th, 2016 11:48 AM
my cafe build. Gregjnolan 1986 - 2007 Ninja 250R Farkles 9 April 24th, 2016 04:01 PM
My 07 250 cafe racer build elephantman78 1986 - 2007 Ninja 250R Farkles 12 December 25th, 2014 07:09 AM
My Cafe Racer Build girlracer 1986 - 2007 Ninja 250R Farkles 17 December 2nd, 2014 08:14 AM
99 Ex 250 project Cafe/streetfighter, The build thread. cerberusrex25 1986 - 2007 Ninja 250R Tech Talk 260 June 14th, 2014 04:27 PM
