Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old July 13th, 2020, 10:24 AM   #1
SpeedDemon22
Motorcycle(s): 2014 Kawasaki Ninja 250R
Bike won’t start and it could be anything.
Hello friends, as I said I have a 2014 Kawasaki Ninja 250R that doesn’t want to fire up. All the lights come on and when I hit the starter button it turns over but won’t catch. I took out the starter solenoid relay and upon inspecting it and pulling out one 30amp fuse Ifound only one side has brass connectors inside. That has to be why she won’t start right. Please help.
SpeedDemon22 is offline   Reply With Quote
Old July 13th, 2020, 10:41 AM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
SpeedDemon22! Glad you found us...
Old July 13th, 2020, 11:27 AM   #3
Ceeloo Yello
Motorcycle(s): 250
Welcome, I believe if there was no continuity the bike would not crank.
Old July 13th, 2020, 12:25 PM   #4
/moved to new-gen tech
Old July 13th, 2020, 12:27 PM   #5
To clarify - this is a 2014 250? Did Canada still get the 250 in 2014 rather than the 300, or they got both?
Old July 13th, 2020, 06:31 PM   #6
If starter spins engine, it's working perfectly fine. Other areas to look at:
- power going to ignition coils?
- spark-plugs OK?
- ignition fuse OK?
- power going to ECU?
- power going to injectors?
- power going to petrol-pump?
- EFI fuse OK?
- how much petrol is in tank?
- has ignition-switch ever been replaced?
- MAP-sensor connected? vacuum hoses connected properly?
- crank-sensor connected? positioned-properly away from flywheel?
- TPS-sensor connected? Is it rotated properly? Idle-switch engaged?
Any one of these can cause no-start condition. It's very likely you may have more than one.
Last futzed with by DannoXYZ; July 14th, 2020 at 11:51 AM.
Old July 14th, 2020, 06:35 AM   #7
- spark-plugs OK?
- ignition fuse OK?
- EFI fuse OK?
- TPS-sensor connected? Is it rotated properly? Idle-switch enaged?
That was going to be my next question...
If it's cranking/spinning-over properly you need to look at ignition or fuel.
How old is the gas?
Did you check for spark?
Old August 2nd, 2020, 07:44 AM   #8
Welcome!
Bike won't start and backfires when trying to start TrickyTriggs General Motorcycling Discussion 30 April 16th, 2018 08:35 PM
bike won't start... nebraskan 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2011 01:48 AM
bike won't start :/ SephiaSputnik 1986 - 2007 Ninja 250R Tech Talk 20 March 12th, 2010 02:40 PM
