Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old May 10th, 2021, 10:46 AM   #1
davidhadiprijanto
Motorcycle(s): 2019 Ninja 400 ABS
ABS Main Harness (Front) broke - advice?
The ABS light on my 2019 Ninja 400 remains ON while riding. Using the Self Diagnostic, it gave me error code 43 (Front wheel rotation sensor wiring issue). Upon inspection, turns out one of the wire from the main harness to front wheel rotation sensor connect broke (link to picture below).
Am I SOL and have to replace the entire main harness or is there another way to fix it?
https://photos.app.goo.gl/3U63DxvZwF6dHqsi8
Last futzed with by davidhadiprijanto; May 10th, 2021 at 10:48 AM. Reason: add image link
davidhadiprijanto is offline   Reply With Quote
Old May 12th, 2021, 09:21 AM   #2
Here's the pic:
Hopefully it won't require a full harness replacement; free bump for more views to chime in as well.
Old May 12th, 2021, 11:42 PM   #3
xx_sevendayz
Motorcycle(s): EX250J
It looks like an easy fix.
from my experience, you can buy a replacement socket and rewire it.
xx_sevendayz is offline   Reply With Quote
Old May 13th, 2021, 06:16 PM   #4
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
You got some good replies in the thread on the other forum, but I'll repeat some of what was said for the benefit of anyone else who stumbles across this thread.
The connector looks like it's a Yazaki HS025.
If you can figure out how to get the pins out of the housing, it should be relatively simple to crimp/solder (assuming you've got the tools/skills to do that) a new $0.15 terminal on the wire and stick it back in the housing. The biggest issue is probably the 1/4" of wire length you're losing, if it's that tight to begin with. Or just cut the other wire at the plug and install a whole new $2.85 plug on the end of the wires.
If you email Joe at Cycle Terminal, he may be able to give you some tips for getting the connector apart. Some of those are fairly complicated multi-piece housings that have to be assembled in a certain order to end up with a nice sealed final product. And some are designed to never really come apart once they're assembled too.
You could technically replace it with basically any sealed 2-pin connector. However, that means you're modifying both the harness and the sensor. If you ever have to replace the sensor, you'll need to chop up the new one to put the non-OEM connector on that too.
It's not like you're hacking up a Lamborghini or anything, but it could also affect resale value. If I saw a factory connection with a generic connector swapped in without a good reason, I'd be wary of what else had been done to the bike. I would assume they didn't really know what they were doing and/or took shortcuts on repairs, and I would assume there was more stuff like that whether or not I could see it. Not everyone is as picky as me, but questionable electrical stuff can definitely scare people away quickly.
Need 2009 main Wiring Harness rojoracing53 Items Wanted 2 February 25th, 2015 09:40 AM
Broke Off Valve Cover Bolt off any advice cuz 2008 - 2012 Ninja 250R Tech Talk 19 September 22nd, 2012 08:48 AM
