Go Back   ninjette.org > Marketplace > Motorcycle-related
Old July 20th, 2021, 12:36 PM   #1
mgentz
Board Member
FS 2009 Kawasaki Ninja 250
Currently located around Sarasota, FL. Milwaukee WI, but I am moving to the St. Louis MO area soon and could deliver along that route.
17,XXX Miles
Clear and Clean Title
No Accidents and never down
Maintained EXTREMELY well
All stock and spare parts that I have will be given to the buyer as well. There are way too many to list, but I can think of: Stock carbs, spare sprockets, spark plugs, gaskets, rearsets, some crank bearings, other random bearings, some bolts, K&N pod filter, many jets and much more!
ASKING PRICE $5000
Will post current pics soon.
Summary of Motorcycle:
Suspension
Forks were redone and optimized by Ed Sorbo of Lindemann Engineering (Ed also added fork drains at the bottom of the forks so I can do oil changes w/o removing the forks.)
SSR Preload caps
Penske triple with LE valving and short reservoir hose (will mount to battery box)
Springs front and rear are based on my weight and riding style.
2010 Aluminum shock triangle for less weight!
SSR preload caps
Ignition
BRT-is
NGK CR8EIX plugs
Takai Racing Coils
Engine
APE Ported head with +1.5mm intake valves
APE custom springs
New guides, seals and retainers
Falicon ultra light crank mods
Falicon gram matched, shot peened and polished rods with bronze bushings
JE 13.5:1 pistons +2mm
BEET cams both intake and exhaust
newer cam chain
newer cam chain tensioner
ISF polished transmission gears
Worldwide ceramic transmission bearings
Custom SS oil line
Newer water pump and hoses
Nikasil cylinder coating
Thermobob 3
Engine EGR block off plates
Lots of new seals, gaskets and consumables
Fuel/Intake
CR31 carbs full complement of jetting
Ported stock airbox
heat shield added to rear of engine for cooler air
heat shield added to underside of gas tank
Exhaust
Leo Vince carbon superbike exhaust with custom header flanges that perfectly match the head and pipe for superior flow (I don't need to use gaskets). Pics elsewhere
NGK A/F ratio gauge installed
Frame and Controls
Motion Pro VR Throttle (50mm cam)
Motion Pro Right Cluster Switch
Heated Grips
WC Clip-ons
Stainless bolts where I could easily replace
Aluminum gas cap bolts, full aluminum race spec engine kit from ProBolt, AL sprocket nuts, TI brake bolts, TI oil drain bolt
Lightech Rearsets
Ohlins damper with BEET mount
Brakes
@rojoracing53 modified rear brake rotor (shaved off 13 oz or so!!!)
@rojoracing53 modified rear brake hanger (captive)
Braking full floating front rotor
Vesrah SJRL front pads
SS brake lines (both custom)
Brembo RCS15 radial master, reservoir, and custom bracket
Rear reservoir delete
Other Fun Stuff
Newer tires
MicroBlue Ceramic Wheel Bearings
New sprockets with a 520 non-oring chain (15/43)
Engine Ice high performance coolant (no mixing)
Yoshimura Fender eliminator
Fully safety wired past WERA/AMA specs
Kawasaki DB windscreen
Spears Racing Chain Holder
Battery Tender
Super Bright Full LED tail light
Captive front wheel spacers (eliminates speedo)
Probably more that I am missing. Truly a sight to see!!!
Old July 20th, 2021, 08:05 PM   #2
mgentz
Board Member
Pics
Old July 20th, 2021, 08:07 PM   #3
mgentz
Board Member
More pics
Old April 7th, 2022, 11:13 AM   #4
mgentz
Board Member
BUMP
Old September 15th, 2022, 10:53 AM   #5
mgentz
Board Member
BUMP
Now located in Sarasota, FL. I'll drop price to $4500
If no serious offers, I may part it.
Old October 11th, 2022, 02:01 PM   #6
mgentz
Board Member
Anyone want parts? If I can get buyers for the major items, I’ll part it.
Motor
Frame
Suspension
Otherwise $4250 is pretty darn low for this thing
Old October 31st, 2022, 09:27 AM   #7
mgentz
Board Member
$4000 for the bike is as low as I can go.
Wont find a better deal anywhere on such a nice bike.
Last futzed with by mgentz; December 1st, 2022 at 07:43 AM.
Old October 31st, 2022, 05:33 PM   #8
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
It's unfortunate but next to no one wants to pay premium for a tricked out ex250. Not sure what the 250cc racing scene is like these days either with all the small displacement increases in new bikes over the years.
When I sold my 250 I ended up tearing it down and trying to turn it back to stock as much as i could and sell off the extras separately but I didn't really have any engine work either though.
Tough market, good luck man.
Old October 31st, 2022, 06:22 PM   #9
mgentz
Board Member
I would part it out if I could find someone that wants the major parts. I would even strip it down to as much of stock as I could, if I had a buyer for some of the “race” parts. I’m open to options.
However, if someone wants the whole thing, they will get one heck of a machine
Old November 2nd, 2022, 04:40 AM   #10
Topaz
Topaz's Avatar
Beautiful bike! What a shame to have to part it out.
Old November 2nd, 2022, 11:19 AM   #11
mgentz
Board Member
I would like for it to go to a good home!
Also, I cannot edit my original post, but I am now located in Sarasota, FL. Hopefully that helps!!!
Old November 2nd, 2022, 11:42 AM   #12
thedrewski86
thedrewski86's Avatar
I would love to take over ownership if I actually had any need of it
That's the same paint scheme as my wife's old new-gen we had back in the day. I like the new-gen 250s but they're obsolete like everything nowadays. I'm just steady rolling with my moldy-oldie first-gen.
Don't think, look!
Old November 2nd, 2022, 02:49 PM   #13
Edited.
Old November 3rd, 2022, 10:55 AM   #14
Seems race-bikes are moving pretty good on various FB groups. I've had several get sold before I even had chance to contact seller.
Old November 3rd, 2022, 05:45 PM   #15
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
race scene should be decent in Florida, should definitely help a bit.
Old November 6th, 2022, 02:38 PM   #16
mgentz
Board Member
Which FB group do you recommend?
Old November 6th, 2022, 02:39 PM   #17
mgentz
Board Member
I would hope so. I want to sell but I may just end up keeping it and using it at the local kart/mini track.
Old November 6th, 2022, 02:46 PM   #18
I always wanted to try mine on the kart track. I've taken another bike there, but not the Ninja.
Old November 30th, 2022, 01:09 PM   #19
mgentz
Board Member
Any takers....? Whole bike, engine, suspension, etc?
Old December 1st, 2022, 07:44 AM   #20
mgentz
Board Member
Please do tell which groups
Old December 1st, 2022, 08:42 PM   #21
ROB654
Motorcycle(s): 08 NINJA 250,EX500,YSR50,86 VFR750
How much for motor? Also how much for the carbs?
ROB654 is offline   Reply With Quote
Old December 2nd, 2022, 06:04 AM   #22
mgentz
Board Member
Another member here told me $2000. That sounds fair to me.
Carbs for $300 with the motor. I would include my spare jets as well.
Old April 14th, 2023, 05:02 PM   #23
mgentz
Board Member
Motor
Frame
Suspension
Open to parting the bike out. Send me offers for what you want.
Otherwise willing to let the whole thing go for $3000 at this point. I need it gone.
Last futzed with by mgentz; April 17th, 2023 at 09:34 AM.
Old April 17th, 2023, 03:46 PM   #24
mgentz
Board Member
$3000 for this is a great deal. A track ready weapon or a 50mpg street bike. This thing is both.
Old July 13th, 2023, 06:38 AM   #25
mgentz
Board Member
Nobody is in for $3000? What would someone on here pay?
Old September 30th, 2023, 05:58 PM   #26
mgentz
Board Member
How about $2300. Bike Only. Does that get anyone's attention?
PM me if interested and come pick this thing up.
Old October 1st, 2023, 07:15 AM   #27
ducatiman
ducatiman's Avatar
I'll submit you are an obvious victim of the current radical economic downturn.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old October 1st, 2023, 03:17 PM   #28
mgentz
Board Member
It appears I am.
I just sold that bike locally for all of $2500. With $15,000+ into it, including the original purchase price, I am a little sad that it took that much to give away such a great bike.
Oh well....Look for a spare parts thread to show up soon. At least others should be able to purchase my spares for cheap to keep their bikes running!
MODERATORS - Please mark as sold.
