Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old March 16th, 2022, 07:08 AM   #1
Rstark
Motorcycle(s): 2016 Kawasaki Ninja 300 ABS KRT
Lightbulb Gas cap
Okay, so I’m had a gas cap that was frozen and wouldn’t open. I used plastic pry’s for over an hour, and I finally opened it. I replaced it with a new one but with a different key. The cap does not sit flush to the tank. I’ve tried taking out all bolts on the cap and tried to level it while tightening the bolts. One side sticks up about 2 or 3 millimeters, the opposite side is flush. Is there any trick to seating the entire gas cap so all of it is flush?
Rstark is offline   Reply With Quote
Old March 16th, 2022, 08:40 AM   #2
take cap off and measure depth of mounting pads from surface. All that prying may have bent some. Tap ones that are too high back down, maybe use wooden dowel. Go slowly and measure often. When they're same depth, test-fit cap to see if flush. Repeat measurements and adjustments as necessary.
If measured depth is identical, then something else is wrong.
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
Gas coming out on SSR threaded keyless gas cap. Topaz 2013 - 2017 Ninja 300 Tech Talk 15 September 25th, 2018 01:01 PM
