Go Back   ninjette.org > 2018+ Ninja 400 > 2018+ Ninja 400 Tech Talk
Old April 10th, 2022, 08:37 PM   #1
pb3
Motorcycle(s): 09 n250, 14 n300, 22 n400
rear wheel sensor, sprocket change?
hi all,
noticed on my non-ABS '22 there is a "rear wheel rotation sensor." I have yet to find the rationale in the service manual, is this just for speedo operation or more?
also, anyone change sprocket sizes without an ECU fault generated?
tia,
parker
pb3 is offline   Reply With Quote
Old April 11th, 2022, 07:10 AM   #2
Rear-wheel speed sensor is for ECU to determine what gear you're in for gear-indicator on dash. Is it still indicating correct gear?
What ECU code# are you getting? If it's #25, it's gear-indicator routine that's complaining about new engine-speed to wheel-speed ratio. How many teeth did you change sprockets? Seems limit is right around 7.1% change or more is when it starts complaining.
To clear and reset error code:
- unplug clutch-switch under clutch lever
- jumper connector on harness side with U-shaped wire, or paper-clip (warning: this will allow bike to start in gear. So make sure it's in neutral with clutch-lever squeezed before starting).
- start engine and idle for 30 seconds.
- ride for at least 10 minute with 5 or more minutes above 20mph.
- turn key off to shut bike down
- repeat 3 more times
- on 4th start errors will clear and everything functions normally again
Old April 11th, 2022, 09:59 AM   #3
pb3
sorry, no codes yet! and no sprocket changes. only 259 miles.
7.1% change, can you check my math to make sure I'm understanding...
on my 250, oem was 14/45. i installed 14/44. 3.214 vs. 3.143 meaning 2.2% change?
on my 300, oem 14/42, installed 14/40. 3 vs. 2.857 = 4.8%?
Old April 11th, 2022, 11:22 AM   #4
Math looks good.
What gearing are you changing to on 400?
Seems there's some annoying buzziness at 5500rpm cruising-speed that people change gearing to get away from.
Old April 11th, 2022, 11:56 AM   #5
pb3
i'm not sure, what are your suggestions? OEM is 14/41
Old April 11th, 2022, 08:13 PM   #6
Seems Ok ratio to me, I like it as it is. Try it and get used to it. Then when it comes time to replace chain & sprockets, you might have an idea of changes you want, if any. Most people add tooth or two for faster acceleration on track. Commuters add tooth in for more relaxed cruising.
[motorcyclenews.com - sport] - HRC introduces rear wheel speed sensor protector in Se Ninjette Newsbot Motorcycling News 0 October 10th, 2013 03:41 AM
[motorcyclenews.com - sport] - HRC introduces rear wheel speed sensor protector in Se Ninjette Newsbot Motorcycling News 0 October 10th, 2013 01:40 AM
front vs rear sprocket change sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 June 25th, 2012 03:32 AM
Rear sprocket change red 2008 - 2012 Ninja 250R Tech Talk 16 November 20th, 2010 07:30 AM
