Old July 9th, 2022, 04:33 PM   #1
Fred659
Fred659's Avatar
Motorcycle(s): 08 Race Prepped ZX-10r, 09 Race Prepped Ninja 250 (300 motor). 74 Norton Commando 850 (Project)
DIY - Oil Cooler Kit
Hi everybody,
It's been a long time since I posted here but I think this is a good one. My race ninja 250 now has a 300 engine in it (RIP 250) and it has 43 hard working horses at the wheel. Last year, the water temp was always 110c at the end of my sessions and I had to change the oil quite often. Long story short, I decided to put an oil cooler on the bike, yes for cooling, but for the extra oil capacity too. I now use 10w50 oil in the bike.
The hard part was to find the plate that would fit the 300 bloc. the rest is pretty strait forward. You can see the machining on the plate on the pictures of the plate on the bike. Now the temp stay below 100c and oil at around 110c. Please note that I have a Yosh full system and hoses routing can vary on your application. I did put some header tape to reduce the heat near the hoses just for safety.
Hi hope that my thread will help some of you guys. So, the most economic way I found is the following:
Sandwich plate: GReddy Engine Oil Block Cooler Sandwich Plate Adapter, Type E M20 x 1.50 -10AN (it has a thermostat)
You need to shave the plate to have a max diam of 71mm or it wont fit the 300 block. The adaptor is m20 to 3/4-16
https://conceptzperformance.com/gred...al_p_31777.php
Oil Filter : Wix WL10239 or Toro Equivalent
this is important because you need to have the gasket of the filter on the flat part of the plate and the stock filter won't do the trick.
wixfilters.com/Lookup/PartDetails.aspx?Part=2162117
Oil cooler : 2003–2012 sv650
AN10 fittings for the Oil Cooler (2X): AN10 to m12 x 1.0mm
https://www.amazon.ca/-/fr/gp/produc...?ie=UTF8&psc=1
AN10 fittings kit: cheap amazone one.
Temp Gauge: Cheap ebay / amazon one
https://www.ebay.ca/itm/164301269908...MAAOSwA8VfF-GP
Last futzed with by Fred659; July 9th, 2022 at 04:34 PM. Reason: add thermostat comment
Fred659 is offline   Reply With Quote
Old July 9th, 2022, 06:08 PM   #2
Topaz
Topaz's Avatar
Very impressive!
@Ghostt may enjoy this post, as he's working on fitting a 300 engine in a 250.
Old July 16th, 2022, 09:22 AM   #3
Ghostt
Ghostt's Avatar
Originally Posted by Topaz View Post
Very impressive!
I had an oil cooler on the bike before the engine went. Not planning on putting one on at this time.
I don't race the bike, and it will get limited use, as I have other bikes to ride, but we shall see.
Looks like a clean install, well done @Fred659
violente et ignorantia
ZX-2R BLOG
Old August 5th, 2022, 08:03 AM   #4
Nice work!
Old November 29th, 2023, 11:56 AM   #5
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Good work but why not just put a cooler on the head lube hose ? I did that on my ZZR250 �� Much simpler to plumb in.
Old November 29th, 2023, 11:59 AM   #6
Fred659
Fred659's Avatar
Because I wanted it to be rheostat controlled.
Ninja 250 Engine Oil Cooler DaBlue1 2008 - 2012 Ninja 250R Tech Talk 78 November 10th, 2016 12:47 AM
[webbikeworld.com] - Cox Racing Group Radiator and Oil Cooler Guard Review Ninjette Newsbot Motorcycling News 0 December 12th, 2015 08:01 AM
[webbikeworld.com] - R&G Radiator and Oil Cooler Guard Review Ninjette Newsbot Motorcycling News 0 December 12th, 2015 08:01 AM
FS: Asia Works 250R Oil Cooler DJK Motorcycle-related 11 June 10th, 2015 08:05 PM
