October 23rd, 2023, 10:25 PM | #1 |
Join Date: Oct 2023 Motorcycle(s): None yet, but fixing to build my first Posts: 2
Engine Swap
Alright guys. I know nothing about bikes and am starting a build. I was wondering if a 2015 Ninja motor would fit on a EX250J frame.
October 24th, 2023, 02:59 PM | #2 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 479
It should slot in on the rear mounts & mate to the top mounts with a small modification or you can get the 300 top mounts & bolt them straight in. I'm working on the same for my ZZR250 to become a ZZR315 big bore Ninja 300 with high compression pistons. This should take it from approx 26rwhp to approx 44rwhp with Fi, which should make it a mini missile ��
October 27th, 2023, 02:36 PM | #3 |
Join Date: Jan 2020 Motorcycle(s): 08 Race Prepped ZX-10r, 09 Race Prepped Ninja 250 (300 motor). 74 Norton Commando 850 (Project) Posts: 56
It fits as I did it myself.
I swapped an entire engine with harness and ecu into my 250 frame. I have k&n filter, full yosh exhaust and ecu flash that gives me 43 whp here are all my threads: https://www.ninjette.org/forums/sear...archid=6187882 have fun with you project! |
Engine swap | john pierson | 2018+ Ninja 400 General Discussion | 3 | June 17th, 2018 08:15 AM |
Engine Swap help | cpayton0 | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 24th, 2017 03:19 PM |
engine swap | iflylow | General Motorcycling Discussion | 4 | October 24th, 2017 12:30 PM |
engine swap | ubxssangz | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 28th, 2013 08:29 PM |
engine swap | almanza2010 | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 16th, 2011 11:50 AM |
