Old May 10th, 2024, 08:24 PM   #1
doubleJ
Motorcycle(s): 2008 Green Ninja 250
Fuel Gauge Sensor Nipple Dripping
Hello...
I just got my gas tank repainted.
When I put it all back together, the little nipple on the fuel gauge sensor is dripping fuel.
I don't recall removing a hose and multiple threads have pointed out that nothing should be connected to it.
Is it possible that the sensor mechanism was damaged in transit or the painting process?
I'm assuming that it shouldn't be leaking.
Would there be an issue with just covering the nipple?
Does it need to "breathe" or anything?
I'm supposed to be riding it, tomorrow, so a quick reply would be greatly appreciated.
Thanks...
JJ
doubleJ is offline   Reply With Quote
Old May 12th, 2024, 09:36 AM   #2
From looking at photos of the sensor, it pretty much has to either be leaking where the flange seals to the tank, or where the wires come out. A careful drying and inspection may let you see which it is.
Old May 12th, 2024, 11:00 AM   #3
doubleJ
I took the black plastic cap off (where the nipple is) and I tightened the 4 bolts.
I was able to move them, but I didn't want to over-tighten them and strip the holes.
I took it to a shop to put new handlebars on and I'm going to have them make sure they are torqued to spec.
If it's still leaking, I will replace the gasket.
I don't know why it started leaking.
I'm guessing something must have happened during transport or painting.
JJ
Old May 12th, 2024, 11:28 AM   #4
Maybe the paint was baked and the heat changed something.
Fuel dripping fast from the vent tube / line MagnaMan 1986 - 2007 Ninja 250R Tech Talk 12 November 20th, 2016 09:07 PM
Replace Fuel Gauge with Fuel Light? Proteus 2008 - 2012 Ninja 250R Tech Talk 8 December 2nd, 2014 08:33 AM
My video on how to fix the fuel sender for your fuel gauge Klint 2008 - 2012 Ninja 250R Tech Talk 1 November 2nd, 2013 09:04 PM
Took off fuel tank and petcock is dripping gas... Navigon 2008 - 2012 Ninja 250R Tech Talk 31 February 4th, 2013 07:16 PM
Fuel tank/Fuel gauge issues coolcatjames 2008 - 2012 Ninja 250R Tech Talk 10 August 23rd, 2012 06:25 PM
