Closed Thread
Old August 28th, 2008, 02:23 PM   #1
Directory of all 250R DIY threads on Ninjette.org
Here is a directory of all DIY ("do-it-yourself") threads for the 2008+ Ninja 250r here on Ninjette.org. If you see a thread that you think should be included in here please PM me and I'll add it to this post.
General Maintenance
Lifting the bike onto stands
How to keep screws organized during maintenance
DIY: Changing Tires on the 250R
DIY: Building Your Own Tire-Changing Station
DIY: Tire Mounting Stand by RojoRacing
DIY: How to balance tires/wheels with limited tools
DIY: Building a maintenance stand for wheels
DIY: Building an engine stand
DIY: Removing the fairings
DIY: How to Remove the Gas Tank
DIY: Super-Secure Gas Tank Holder (for when your tank is removed)
DIY: Oil Change
Motorcycle Oil Info
DIY: How to lube and adjust the 250R Clutch Cable
DIY: Cleaning/lubing speedometer cable
DIY: Lengthening Ninja 250 OEM Clutch Cable 5mm
DIY: How to Clean/Lube Chain
DIY: Scottoiler vSystem (automatic chain oiler)
DIY: Chain Adjustment and Rear Wheel Alignment
DIY: 600 Mile Service
DIY: Valve Adjustment (with video!)
DIY: Checking valve lash
DIY: Adjusting Valves on '08+ 250r (WITH Pictures)
DIY: Valve Shim Matrix (spreadsheet help)
DIY: How To Change/Replace Your Coolant
DIY: Replacing the clutch cable
DIY: Replacing the fork seals, dust seals and fork oil
DIY: Fixing The Buzzing/Rattling Clutch Lever
Carburetor and Jetting
08 Stock Jetting Specs
Jetting Database
Keihin Needle Spreadsheet
DIY: Getting the jets just right, step-by-step
DIY: Carb Syncing
DIY: EFI Install Walkthrough
DIY: Accessing and adjusting idle mixture screws
DIY: Shimming the Carb Needles... Is it for You?
DIY hint: Read this before shimming the carb needles. Really.
DIY: Shimming the carb needles
DIY: Changing jets WITHOUT removing the carburetors
DIY: Remove carbs in under 10 mins [Video!]
DIY: Drilling your carburetor slides
DIY: Carb Work on 2008 Ninja 250 carbs
DIY: Cleaning the Carburetor - Clogged jets
DIY: Cleaning the Carburetor (external link)
DIY: Cleaning Secret Passages in the Carburetor
DIY: Rebuilding the Keihin CVK Carburetor (external link)
Sounds (Testing) of Good & Bad CV Carb Diaphragm
DIY: Removing the Kleen Air System Hoses and Plugging the Holes on a 08 250R
DIY: Emission block off plate
DIY: Removing the air filter box
DIY: Removing the Snorkel
Drivetrain
DIY: Sprocket Swap
DIY: Replacing the Clutch
DIY: Replacing the Chain
Frame / Suspension
DIY: Adjusting the rear shock preload
DIY: How to lower the front end (raising the forks)
DIY: Lowering the back with Roaring Toyz lowering links
DIY: Removing Fork Caps/Pistons and Springs
DIY: Installing Front Fork Preload Spacers
DIY: Slingshot Racing Preload Adjusters
DIY: home-made preload adjuster
DIY: Installing Andreani Grp Cartridges
DIY: Installing GSX-R Rear Shock
DIY: Rojoracing53's Front-end Suspension setup for track use
DIY: How to install an aftermarket upper triple clamp
DIY: Adjusting Fork Alignment
DIY: 250R steering damper
DIY: eBay Steering damper install
DIY: Sato Rearsets Installation
DIY: Another Type of Rearsets Installed
DIY: Installing a Corbin seat
DIY: Hard locking saddlebags (luggage)
DIY: Another Hardlocking Saddlebags w/ Quicklock
DIY: Yet Another, Another Hardlocking Saddlebag Mount
DIY: Installation of the Givi SBX-401 hard luggage racks.
DIY: Installation of the Givi HR-4 Monokey rack
DIY: Shogun No Cut Crash Kit Installation
DIY: Installing R&G Racing Crash Protectors
DIY: T-Rex Frame Sliders and Spools
DIY: Carrying extra fuel
Braking System
DIY: Installing a ZX-6R Master Cylinder
DIY: Relocating the rear brake reservoir
DIY: Replacing the Front Rotor
DIY: Replacing the Rear Rotor
DIY: SS Brake Lines and EBC HH pads
DIY: Spiegler stainless steel front brake line install
DIY: Apex stainless steel front brake line install
DIY: Replacing Brakepads (Video!)
Exhausts
DIY: Area P quiet core SS Exhaust Install
DIY: Area P Quiet Module Install
DIY: Full Yoshi Install
DIY: Installing Zartan's replacement exhaust hanger
DIY: Installing AreaP Exhaust Hanger
DIY: Installing Evotech Exhaust Hanger
Electrical and Lighting
DIY: What Electrical Items Can be Used and Not Overload the Battery?
DIY: Replacing the Headlight Bulbs
DIY: HID Headlight Conversion
DIY: HID retrofit kit (Tri's)
DIY: Another HID kit from "TheRetrofitSource"
DIY: BKMOTO BiXenon HID projectors with angel eyes halos
DIY: LED Aux/Driving lights install (Mondomotos MM10)
DIY: Replace the '08+ CDI (Ignitor) with the '88-94 CDI
DIY: Troubleshooting '08+ CDI with '88-94 Service Manual
DIY: Keyless Ignition for 08 250
DIY: Dynojet Autotune How-To with PCV
DIY: Installing Koso Gauges
DIY: Vapor Trail Tech Gauges
DIY: Installing an Auxiliary Fuse Block
DIY: Installing a Daytona Temperature Gauge
DIY: Installing a Comagination Headlight Modulator
DIY: Installing Halos
DIY: How to create Daytime Running Lights on a 2 wire system
DIY: Ebay universal gear indicator
DIY: Installing Mirror-Mounted Turn Signals
DIY: Installing Universal Mirrors with turn signal leds (2)
DIY: Installing eBay universal fit / Bike It Trojan Style Indicator Mirrors
DIY: 250R Hazard Lights!
DIY: Relocating the rear turn signals
DIY: Double Blinker Speed
DIY: Installing No-Cut Diode kit from modmy250.com
DIY: Adding LED's (footpeg turn signals, brake light strips, front signals)
DIY: LED flexible tape - additional brake lights
DIY: VEX inspired LED turn signals
DIY: How to install LED front turn signals & relay
DIY: Convert stock signals to flushmount
DIY: Shorten stock turn signals
DIY: Installing the Bikemonkey Integrated LED tail light (an alternate version)
DIY: Integrated Tail Light (cool way)
DIY: Proton Flush Mounts
DIY: Yamaha R6/R1 flush mounts!
DIY: P&P Brake Light Modulator
DIY: Rear Brake Light Flasher
DIY: Strobing Brakelight
DIY: eBay zowwie438 Brake Light Modulator
DIY: Installing a Scorpio i800 Alarm
DIY: Installing Spy 5000m Alarm Remote Start
DIY: Installing Spy 5000m Alarm (new version)
DIY: Installing Gorilla 8017 Alarm System
DIY: How to add an accessory plug for heated clothing or battery tender
DIY: Hot Grips Heated Grips Install
DIY: Integrated jumper cables
DIY: Adding a 12V power outlet
DIY: Adding a clock and ambient temperature gauge
DIY: Another GPS mount solution - "Erector-RAM"
DIY: GPS + Ipod audio solution
DIY: GPS Tether
DIY: Installing a FIAMM Freeway Blaster Horn
DIY: FIAMM Freeway Blaster Low Tone installation (alternate location)
DIY: Installing Wolo Badboy / Stebel Nautilus Horn
DIY: Building in-helmet headphones
DIY: GoPro POV helmet mounting
Hand/Foot Controls
DIY: Woodcraft Clipon Install
DIY: Driven Clip On Install
DIY: less than $100 Clip-ons
DIY: Weighted Bar Ends for Clipons for FREE!!! (almost)
DIY: Zip-tie Throttle Tube Mod
DIY: Installing Pazzo Adjustable Levers
DIY: Bikers Rear sets
DIY: Bikers Rearsets Installation Video
Cosmetic Mods
DIY: Modifying the rear fender
DIY: R&G Tail Tidy / Fender Eliminator
DIY: Rumble Concepts Fender Eliminator
DIY: Hotbodies Fender Eliminator
DIY: Jardine Fender Eliminator
DIY: Yamaha tire hugger modification and install
DIY: CBR 250 Hugger install on 08+ Ninja 250r
DIY: Using the Passenger Pegs as Front Pegs
DIY: Polishing Your Rims
DIY: Recovering seats with Custom Seat Creations Seat Covers
DIY: How to Reshape Your Seat For More Comfort
DIY: Installing a Puig Double Bubble Windscreen
DIY: Painting the Stock Windscreen
DIY: SW-Motech mirror extenders
DIY: Custom Mirror extenders made easy
DIY: $10 Newgen Mirror Extenders
DIY: Applying Vinyl Graphics
DIY: Custom Vinyl
DIY: Painting a Damaged Bike
DIY: Fairing Crack Repair
DIY: Hotbodies Racing Undertail Install (Ninja 250R)
DIY: Sportisi Fiberglass Undertail
DIY: Fixing Scratches in Polished Metals
Alex is offline
Closed Thread
Is there a way for the pictures to be reposted in old DIY threads? Ben M Forum Information 1 September 19th, 2012 08:34 PM
DIY: Search Ninjette.org Like A Pro Jiggles Forum Information 11 November 21st, 2011 04:02 PM
New to ninjette.org from UK R250R New Members 11 November 14th, 2011 12:13 AM
DIY for Koso gear indicator? Not listed in the directory. MotoStrider 2008 - 2012 Ninja 250R Tech Talk 2 July 22nd, 2011 05:06 AM
Thanks for the DIY Threads tlhamon 2008 - 2012 Ninja 250R Tech Talk 2 April 15th, 2009 05:42 PM
