Old September 3rd, 2011, 11:20 PM   #1
NathanF
NathanF's Avatar
Motorcycle(s): 2009 V-Strom 650 ABS
Deflecting Exhaust - Anyone Disassembled Stock Exhaust?
I'm finding that one of my mounted hard bags is getting cooked by the exhaust gas about 6 inches away and 1-2 inches up from the stock pipe. Can anyone think of a cheap and easy way to deflect the output more downwards?
I went and bought a 1 inch copper 45 elbow from Lowes. It just about fits into the outer ceramic thing, and easily fits over the actual pipe. If I sanded it down, I could wedge it in there, but I would need a better way of securing it.
I started to take out the bolts on the end of the exhaust, but one seemed really jammed in there, so I decided to hold off lest I break it. Just wondering if anyone has disassembled it, and if so, if there would be a semi-easy way of adding some sort of deflector like the above.
NathanF is offline   Reply With Quote
Old September 3rd, 2011, 11:27 PM   #2
nickadolph
Motorcycle(s): ninja 250
Could you just bolt a metal plate on the bottom of the bag.
nickadolph is offline   Reply With Quote
Old September 3rd, 2011, 11:41 PM   #3
NathanF
NathanF's Avatar
That may be the ultimate fix, but I'd like to avoid drilling holes in my $200 bags.
Old September 4th, 2011, 12:04 AM   #4
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
You may be able to get some type of adhesive heat resistant foil that you can stick to the bottom of the bag.
k-os is offline   Reply With Quote
Old September 4th, 2011, 12:24 AM   #5
setasai
setasai's Avatar
Hey, I never got the chance to reply to you. Sorry about that. I was thinking something like this might help.
http://www.homedepot.com/webapp/wcs/...&Ntpc=1&Ntpr=1
There is a good chance I'll put some silicone caulking to the bottom of the case as insulation and then one layer of foil tape as a heat shield. Let me know if you find a better option.
Old September 4th, 2011, 03:05 PM   #6
HKr1
IC2(SW)
HKr1's Avatar
Bolts just hold the beauty ring on, muffler is welded together.
Old September 4th, 2011, 04:48 PM   #7
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Just buy a CF Area P - shouldn't have a problem then
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old September 4th, 2011, 07:28 PM   #8
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
Yep chrome ring is just for looks.. I cut mine in half, the top half of the can inside is like 4 different tubes in there then the bottom half is just a preferated tube connecting down to the inlet of the can. Believe there's 2 seperate like plates in there seperating the cans into like 2 sections. Its a really odd design actually lol
#1
greatwhiteninja is offline   Reply With Quote
Old September 4th, 2011, 10:31 PM   #9
Skippii
Milkshake Drinker
Skippii's Avatar
Go to lowes or home depot and look at their clothes dryer exhaust plumbing section. They have all kinds of parts for deflecting heat for less than $10.
"What a sweetheart."- ninja_sleeper to me
Old September 22nd, 2011, 01:41 PM   #10
setasai
setasai's Avatar
HMF Performance End Cap Dimensions?
Nathan and I are trying to redirect the exhaust gases on a stock exhaust downards a little bit because it is grazing the bottom of our sidecases and generating some hotspot blemishes.
We've found this endcap to hopefully modify so that it can push the exhaust gases downwards more and still look nice. Does anybody have this on their HMF exhaust that can measure the dimensions. Namely the base diameter, exit tube diameter and pitch angle?
http://www.motorcycle-superstore.com...T.ac=SLIsearch
Before suggesting other ideas, we've tried raising the sidecases a little bit, and putting thermal heat shielding on the bottom of the cases. Heat shielding works well for radiant heat, not exhaust gases.
Edit: Whoops. Wasnt aware there was a thread started a while ago by Nathan.
http://www.ninjette.org/forums/showthread.php?t=84628
Old September 22nd, 2011, 01:42 PM   #11
NathanF
NathanF's Avatar
Anyone think something like this would affect performance of the bike in any noticable way? (Ignoring the copper and mounting challenges, for the moment.)
Old September 22nd, 2011, 01:48 PM   #12
/merged 'em?
Old September 23rd, 2011, 07:09 PM   #13
setasai
setasai's Avatar
Nobody's got an HMF exhaust they could measure for us?
Old September 23rd, 2011, 10:00 PM   #14
leed
leed's Avatar
Motorcycle(s): Time will tell
By adding it you add relatively minor resistance to flow when compared to the exhaust and it's baffles. The only real issue I see is it not staying put!
Old September 26th, 2011, 05:57 AM   #15
dubojr1
dubojr1's Avatar
I don't think you'll notice any change.
Are you asking for options for mounting the copper as well? I'm thinking just drill some small holes through it and the metal exhaust tip and adding some aluminum rivets. If the slip on fit is not good enough for that option maybe a wrap or two of exhaust tape first then rivet on. Another option depending on the clearance of the "appearance" rings... you could split the copper elbow and then use a SS clamp similar to what you would see on other exhaust system joints.
Old September 30th, 2011, 04:53 PM   #16
setasai
setasai's Avatar
For those that care, it has now been solved.
http://www.ninjette.org/forums/showp...7&postcount=52
Old September 30th, 2011, 05:04 PM   #17
greatwhiteninja
Ridin Dirty
sorry for not posting this sooner.. i found it in my files of pics this is the inside of the can off my 2011, this is the top half of the can, the other end i cant find but its basically a open can in the first half with a large preferated tube connecting from the header pipe to the largest one of those pipes in the pic, the very inner shell of the can behind the black outer can is one large preferated pc with holes all through it and a thin pc of fiberglass packing .. anyway maybe someone would find use of it one day .
this was the end result of cutting like 8" off the stock can and rewelding the beauty ring back on
#1
Old September 30th, 2011, 05:17 PM   #18
setasai
setasai's Avatar
Oh cool. That's interesting. Was there a particular reason why you did that in the first place? For looks/fun/sound?
Old September 30th, 2011, 05:36 PM   #19
greatwhiteninja
Ridin Dirty
!sound lol
#1
stock 09 exhaust bruce71198 Free stuff! 9 October 1st, 2018 04:45 PM
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust c-dog Motorcycle-related 2 September 12th, 2014 10:48 AM
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 SON1C 2013 - 2017 Ninja 300 Tech Talk 4 August 14th, 2014 05:45 PM
WTB: Stock rear links and stock exhaust for 2008 bluninja08 Items Wanted 1 July 14th, 2011 10:21 AM
WTB: Area P full exhaust (or exchange 08+ stock exhaust) mikecronis Items Wanted 0 June 16th, 2010 05:54 AM
