#1 |
Join Date: Apr 2012 Motorcycle(s): Ninja 250R 2008 - Green Posts: 14
Front brake lever stiffer after heavy braking
Hello!
Well yesterday I was riding and decided to practice emergency braking. After two runs from 40mph, my front brake lever feels a lot heavier and stiffer than before. Has anyone experienced a similar issue? I prefer the front brake as it was before. It used to be lighter and I could pull in the brake further. Thank you! |
#2 |
Honestly, it sounds like it's better to me. Are they relatively new rotor or brake pads?
#3 |
#4 |
Typically, the hotter you get the brakes, the worse they feel. From your post, you seem to be experiencing the opposite.
When I redid the pads on my r6, I didn't do a good job bleeding them. I still had air in the lines when I arrived at the track. A few sessions later I had great brakes. They got hot... The next day, I could feel they had returned to being somewhat mushy. Check yours again after allowing them to cool off. Possibly from your ebrake practice, you got them hotter than you normally would. So I would suspect, they will return to the old feel. Either way, sounds like you might need to inspect/bleed them well just to be sure.
#5 | |
![]() Quote:
Something may be wrong, probably in the master cylinder or in the fluid itself. Normally, you squeeze it, the lever pushes the plunger, which pumps fluid down into the caliper which pushes the pads against the disc. When you liberate the lever, an internal spring pushes the plunger out, which sucks fluid up from the caliper which retrieves the pads from the disc. There is also a relieve hole in the master cylinder for returning fluid back to the reservoir. If that one gets plugged, the pads don't come back. If only happens when the pads are hot, then you may have humidity in the fluid, which becomes steam and acts like you are pressing the lever. For all the above, it is important that you check if it is temperature-dependent, if the pads are dragging and if the pivot of the lever is properly lubricated (to move freely).
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#6 |
This happens to me too a little bit. It means you have a tiny bit of air or water or something in your lines. A perfect bleed wouldn't have this issue.
My solution is to just give the brake lever a good hard squeeze or two at the beginning of each ride before I take off for the first time. Gives me proper brake lever feel for every ride |
Front brake = left lever; Clutch = right lever | cadd | Riding Skills | 27 | October 7th, 2014 08:29 AM |
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal | 1LoneWolf | Items Wanted | 3 | July 8th, 2013 02:50 AM |
Is this normal under heavy braking? | Lil_Green_Demon | Riding Skills | 11 | January 4th, 2012 07:28 PM |
